7.3L IDI Crate Motor - are these still available? - Ford Truck Enthusiasts Forums
Old 01-09-2007, 03:21 AM
Cool6.9DieselGuy Cool6.9DieselGuy is offline
Cool6.9DieselGuy is starting off with a positive reputation.
I think my 6.9L is having some cavitation issues so I'm considering just dropping in a brand new crate motor, does anyone know if you can still get a 7.3L IDI crated and who/where has the best prices?
Old 01-09-2007, 04:19 AM
Baradium Baradium is offline
Baradium is starting off with a positive reputation.
Quote:
I've been told from unnamed sources that with the new foundry process (International can do a run of a single block because they can make castings on the fly on a per run basis) that when you get a reNEWed engine (that'll be the International branded rebuild) they occassionaly are new blocks. Basically, it seems that if they run short on blocks getting bad cores etc they will make a run of them to keep up the supply. However, you *cannot* request or otherwise buy a block like that for a re NEWed engine specifically.
I don't believe International lists a new engine. I believe a 7.3IDI will be a D-444, but I'm not sure. A DT-444E is the International version of what ford called the PowerStroke.
http://www.internationaldelivers.com...wedengines.asp
http://www.internationaldelivers.com...denginesv8.asp
International contracts with Delco Remy/FPP for the V-8 engines.
Apparently Ford discontinued the part number and got rid of what engines they had in the supply chain.
I don't know if Ford can get reNEWed parts, but International dealerships can easily enough. Scout Light Line suppliers can as well, but don't know if they can get more medium truck type parts easily or not.
Some International dealerships aren't very friendly if they realize you aren't getting a big truck part, but the 6.9 and 7.3L engines were used in a lot of dump trucks. The international spec'd parts will also be heavier duty than original Ford ones (this remains true today, one reason why a new Ford might have an issue that International trucks don't).
This information is mostly from a diesel mechanic I know, some of it is a mixture of information gathered since I'm big into the International vehicles.
Old 01-09-2007, 04:27 AM
Agemenon's Avatar
Agemenon Agemenon is offline
Agemenon is starting off with a positive reputation.
Do you got some white smoke and coolant missing?
Old 01-09-2007, 10:01 AM
vtjvt's Avatar
vtjvt vtjvt is offline
vtjvt is starting off with a positive reputation.
motorworks out of spokan washington build a nice 7.3
Old 01-10-2007, 05:33 AM
Quote:
I have some white smoke that I only see in my mirrors at night on the highway, coolant missing and I smell coolant sometimes too, I basically know there's gotta be a small headgasket leak, I try not to drive the truck till I can pull the motor and regasket it but i'm considering some other options also while considering the cavitation factor and all... also the other night my antifreeze was low and I saw some white bubbles/clouds in the radiator and wasn't sure if that was oil or just bubbles in the coolant, filled it up and haven't seen anything in the radiator yet that I would think would be oil and haven't seen those white clouds anymore either
Baradium I checked out those links, thank you
Old 01-10-2007, 04:35 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
When the head gaskets are getting ready to go, look for coolant around the rear two glow plugs. #7 & #8 cylinders tend to get most of the oil coming out of the CDR, which raises the cylinder pressures in those two cylinders. The head bolts stretch and let coolant seep out or compression to seep into the cooling system.
Servicing the CDR every other oil change or more often can prevent this problem.
Old 11-29-2015, 10:43 PM
davlun davlun is offline
davlun is starting off with a positive reputation.
Old thread, just looking for new links. Tried your links, tried some searches. Do they still do this?
Old 12-02-2015, 04:51 AM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is offline
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
First that ive ever heard of it. Odds of a 6.9 cavitating are pretty slim, only heard of it twice with a 7.3 and theyre "plagued with cavitation problems". 90% of the time its headgaskets, and the other 9.9999% is the oil cooler.
Last time i was in the Ford stealership they had a nice parts mat on the counter that listed the 6.9 - 6.0 as available from Ford / IH as rebuilds. Want to say $4995 for a new 7.3, 6995 for a PSD and like 9k for a 6.0.... granted this has been about 8-10 years ago. Dont even look at Jasper, let alone buy one. We had ours rebuilt local for around 5k, had to be sleeved, (ate a valve). New pistons, valves, balanced etc.
Old 12-03-2015, 10:28 PM
Thanks. Hopefully I do not need a rebuild... that would be extremely unfortunate for me, no funds for that at the moment.
David
Old 12-03-2015, 10:45 PM
wtroger wtroger is online now
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
I rebuilt a few 7.3 engines and the problem with them is just replacing the head gaskets with out decking the block and resurfacing the heads is pretty much a waste of time. The firing ring grooves that show up on the heads and the block needs to be removed to ensure head gasket sealing. Of course this means removing and totally tearing down the engine.
V10 Crate motor brcowan Modular V10 (6.8l) 19 02-03-2016 11:02 PM
6.9 to 7.3 swap Nathan Cox 1987 - 1996 F150 & Larger F-Series Trucks 3 10-27-2015 07:52 AM
The Great Engine Choice Debate: Gasoline or Diesel AZAV8 1948 - 1956 F1, F100 & Larger F-Series Trucks 36 06-14-2015 04:03 PM
460 crate motor Pro725 1997 - 2003 F150 6 12-07-2008 01:54 AM
solid flywheel? pud Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 57 10-19-2006 10:53 AM
Tags
1989, 69, 73, 73l, 89, brand, crate, diesal, diesel, engine, engines, ford, idi, moter, motor, powerstroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
