Need Info On Rear End Replacement
I have the rear end vibration that several people have posted on various sites. It starts around about 50mph and gets pretty bad at 65 or so. I feel this vibration in my seat, on the floor, but not in the steering wheel. It seems to be coming from the rear. I needed to replace my tires so all 4 were replaced. I then took a file and very lightly dressed the mating surfaces of the wheels to the truck. I then torqued everything with a torque wrench. The vibration was exactly the same. I unbolted the front of the drive shaft and rotated it 180 degrees. Still a vibration. I replaced both u-joints on the main drive shaft and the vibration only got sharper. I then had a drive line shop remove my drive shaft and straighten it. Turns out it was 40 thousandths (.004) out, which though not much, they straightened it anyway. (I never take my truck off road by the way). The vibration remained unchanged. It was also discovered that I had metal in my rear end on the magnet of the drain plug. The mechanic said he thought the limited slip clutches were locked up and causing a shudder. He took the cover off the rear and everything looked good. Replaced the oil and lifted the truck and placed a block of wood under each rear wheel separately and lowered the truck onto the wood to force each side to turn independently of the other. This seemed to free up the clutches. Again, no change to vibration. Drove the truck a thousand miles and now I have metal on the drain plug magnet again. I'm thinking the pinion bearing might be bad, but the metal makes me think the ring gear and pinion would need to be replaced if that were where it came from. Since I'm no expert, I wondered about just swapping out the rear assembly for a late model Superduty truck at a salvage yard. Does anyone know where I can get info on interchangeability for my Excursion?
Thanks.
2000 Excursion
3.73 Limited Slip
7.3L A/T 4WD
Tim
Thanks.
2000 Excursion
3.73 Limited Slip
7.3L A/T 4WD
Tim
Originally Posted by timsexcursion
If it's my pinion bearing and I have metal, wouldn't that mean probably new gears are needed also?
Now since you have a Posi-/ limit slip clutch pack differential have you added the Ford required additive for this differential. If the additive isn't in the oil you will have noise issues from the clutch pack.
If you don't have the additive, add it,, then warm the truck up and do some figure 8's in a parking lot to exercise the clutch pack. If this doesn't help you could have a bearing issue. Axle brg's will roar with wheel rotation speed. Differential pinion will be higher.
Good luck.. Jim
Pinion, bearings , there are 2 of them 1 frt. at the yoke & 1 at the gear it's self . If thay are bad clean & check all the bearing's . I always replace all bearing's even the axle bearing's,flush it out , tourqe to specs. & check back lash !!! Install proper fluid & go !! It's uncommon that this happen's but it will .
Don
Don
Special tools required for replacement or should I take it somewhere?
It is possible using identical bearings and putting shims back in the exact location to open it up change bearing re-use gears and be successful w/o measuring.
- The backlash at the yoke will tell you if the side to side on the ring gear is correct.
- Gear mesh pattern with prussion blue will tell you if depth of pinion is correct.
- Torque in inch pounds at the yoke will tell you if you have the preload correct.
