Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 01-12-2007, 11:59 PM
Tenn01PSD350's Avatar
Tenn01PSD350 Tenn01PSD350 is offline
for now.....
Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold
Quote:
Originally Posted by winn9524
Redsundevil,
how much oil can I expect to come out of the plug as it looks like I have the same problem? Will it be easier to wait for an oil change?
'01 Supercab 7.3PSD Dually XLT 121K
As much as is in there which isn't huge in the grand sceme. The HPOP reservior won't hold that much, and after the leak, who knows? If you don't need a change, just make the repair and top off the HPO reservior with what, about a half quart of fresh oil?
__________________
Mike
Silver truck with a hairdryer and sticks. A lot of other less expensive chit too which adds up to expensive.
  #17 (permalink)
Old 01-13-2007, 10:28 AM
winn9524's Avatar
winn9524 winn9524 is offline
winn9524 is starting off with a positive reputation.
Alrighty,
Thanks for the help guys!
  #18 (permalink)
Old 01-15-2007, 09:21 AM
Redsundevil Redsundevil is offline
Redsundevil is starting off with a positive reputation.
I had a little less than a cup worth of oil come out when I pulled mine, but I'd imagine that could change depending on how recently you've driven the truck, not sure exactly. Luckily I had stuffed a large quantity of rags down in the intake valley before pulling the plug, which helped soak up the majority.
As for waiting for an oil change....my leak was bad enough that it was going to change the oil itself in about 20 miles of driving, so waiting wasn't an option. I suppose you could wait if the leak is slow, just depends on how much it bothers you I guess.
Just a reminder, I didn't have to top-off the HPOP to fix the rough-running condition, I just drove it a couple miles, but it is an option if you want to do it.
  #19 (permalink)
Old 01-30-2007, 06:00 PM
sir62 sir62 is offline
sir62 is starting off with a positive reputation.
Thumbs up thanks for the oil leak repair
After reading the posts, I have deceided I too can "fix" the leak. The last problem was with a fuel leak thanks to the new fuel being forced on us all. Fuel leak was taken care of as the oil leak will be soon.Thanks to all on the FTE for the advice and how to's I will save enough money on repair bills to pay for this computer....LOL
  #20 (permalink)
Old 02-06-2007, 10:25 AM
02F350 02F350 is offline
02F350 is starting off with a positive reputation.
my bottom end plug is leaking does anyone know how to fix this? i have 7.3
  #21 (permalink)
Old 01-30-2008, 04:28 PM
wbeding wbeding is offline
wbeding is starting off with a positive reputation.
hi everyone,
I am new to this site and new to owning a diesel. I recently noticed that my 03 7.3 PSD was leaking oil onto the pavement. I inspected under the hood and found there to be a puddle of oil underneath the fuel bowl. I have read a fair amount of the seals on the high pressure oil pump and was wondering if anyone could offer a detailed procedure and perhaps a diagram or two of potential problem areas.
thanks,
Drew
  #22 (permalink)
Old 02-14-2008, 11:16 AM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
Support FTE
PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of
HPOP Diagram
  #23 (permalink)
Old 02-14-2008, 01:29 PM
HeatStroked's Avatar
HeatStroked HeatStroked is offline
HeatStroked is gaining momentum as a positive member of FTE. HeatStroked is gaining momentum as a positive member of FTE.
Just replaced the "do not remove plug" O ring. The O ring was blown out around the plug and the plug itself was easily removed with a wrench.
Picked up a pump O ring kit at International for a 6 cylinder,had the correct O ring in it.
Cleaned threads, loc-tite green and re-installed.
No problems since.
Ford or International pump rebuild kits for the 7.3 do not include this O ring.
  #24 (permalink)
Old 02-14-2008, 01:51 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
HeatStroked,
Did you remove the HPOP from the engine to do that job? Do you need to keep that port in the "up" position when you pull that plug?
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #25 (permalink)
Old 02-14-2008, 01:52 PM
Quote:
Originally Posted by SpringerPop
HeatStroked,
Pop
Yes and yes
  #26 (permalink)
Old 02-14-2008, 02:04 PM
2000 Ford F-350
I am FIRMLY convinced that the LocTite is doing the sealing job for these plugs, not the o-rings. Both male and female threads have to be spotlessly clean and free from ANY oil residue (I used a lot of Q-tips and brake cleaner) for the LocTite to really seal perfectly.
I'm going on two years of having a Buna (not Buna-N) o-ring and incorrect (blue) LocTite in mine with no leaks.
Sorry, guys, I had to "Micky-Mouse" it one Saturday for a mandatory trip on a Sunday, and it's never leaked since. That was almost two years ago.
The correct o-rings and LocTite ride around in my center console, just in case...
I'll stick to my guns about the o-rings not really being what seals.
Pop
__________________
Email SpringerPop
  #27 (permalink)
Old 02-26-2008, 09:45 PM
zander499 zander499 is offline
zander499 is starting off with a positive reputation.
do u guys know how to keep oil from coming out of th dip stick where i goes in to the oil pan its like hex head looking bolt its on a 99 powerstroe
  #28 (permalink)
Old 04-09-2008, 12:51 AM
StrokeR_7.3's Avatar
StrokeR_7.3 StrokeR_7.3 is offline
StrokeR_7.3 is starting off with a positive reputation.
i got a small leak so i figured id subscribe......
__________________
03 F250 CC SB FX4 7.3 PowerStroke! 56k on the Clock and counting....
4" Lift, 35" M/T, 4" Turbo Back Exhaust, Custom Front/Rear Replacement Bumpers....
  #29 (permalink)
Old 04-09-2008, 01:05 AM
k2vailkid's Avatar
k2vailkid k2vailkid is offline
k2vailkid is starting off with a positive reputation.
Question about this fix...
I've had a steady oil leak for over a year, the service manager at my local stealership keeps saying, "it's a pressure type leak because of the volume of oil that is leaking, and the fact it only happens if the truck is running. If it were a rear main seal, it would just leak the same all the time." He wants to pull the tranny to investgate further, but what is hiding there to look at besides a rear main?
If the valley is totally dry, and it's not a pedestal leak, can any oil come from the HPOP? Any other spots I should be looking at?
Thanks in advance for the assistance, I want to solve this one!
__________________
-Kevin
2003 F250 Lariat 7.3, Turbonetics BB 1.0 w/HFO & no EBPV, Bellowed pipes, all ceramic coated, DP-Tuner F5, Spearco 6.0 CAC, DI Reg fuel system, Tymar, HOG SS 4" Exhaust, A-meters, SS HPX, AIH Delete, Kwik CCV, BTS VB, 203* T-stat, Dynatrac Free-Spin Hub Conversion, 4" Lift on ProComp MX-6 piggybacks w/ ProComp 35's.
Tags
01 , 73 , 73l , diesel , dit , f250 , high , hpop , leak , leaks , liter , oil , powerstroke , pressure , pump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
