02 Explorer 4 wheel drive problem - Ford Truck Enthusiasts Forums
Old 01-08-2007, 11:24 AM
copyman copyman is offline
copyman is starting off with a positive reputation.
Yesterday I noticed when I pushed the 4x4 high and the 4x4 low button nothing happened, there was no light indicator coming on at the dash, and also there was no differece in gears when 4x4 low was selected, is there an easy fix to this like possible a fuse blown? Thanks for any input.
Old 01-08-2007, 04:42 PM
02sporttrac 02sporttrac is offline
02sporttrac is starting off with a positive reputation.
start with the fuses if that doesn't work i would check the wireing to make sure that it did not not come unplugged.
Old 01-08-2007, 04:54 PM
I checked the fuses which were good, next step is to check the wiring. I noticed when I turn the key on to acc and looked at the instrument panel I have the 4x4 low light on but no 4x4 high light don't know if the high bulb is burned out or has somthing to do with the problem that Im having.
Old 01-09-2007, 12:43 PM
i would get ahold of your local dealer or someone who has a computer to check for a code thats wrong in the system. even if the check engine light is not coming on.
Old 01-09-2007, 04:12 PM
Did a little research on this problem and it seems I may have a bad electronic shift control modual for the 4x4 system but can't be sure because I dont have the shop manual on testing the Modual, which cost about $290.00.
Old 01-10-2007, 10:25 AM
edward r edward r is offline
edward r is starting off with a positive reputation.
I have the exact problem as u (and I have the same vehcicle). Please let us know when you have the exact cause nailed down
Old 01-10-2007, 10:33 PM
Rc Moser Rc Moser is offline
Rc Moser is starting off with a positive reputation.
Had that exact problem a couple of months ago. Had the transfer case elect. motor replaced. $547 bucks in my neck of the woods. Mine still don't work after it sets awhile. I disconnect the battery reset the computer and it starts working again. IMO Don't necessary mean it the motor. I try mine every couple of days, so far it works. I hope so, Bad weather is coming in a couple of days. I sure hope I don't have to pull out my 89 Trooper 4x4 with 200K miles on it just to get around in the snow and ice. I posted my problem this morning if you want to see the history of the exact same problem your having. Rc.
Old 01-14-2007, 10:21 AM
I read on another site were a guy had the exact same symptoms as me and it ended up being the 4x4 module. Its located behind the glove compartment, easy to swap out. cost is about 290.00 from ford.
Does anyone know where I can get it cheaper?
Seems like voltage spikes knock theses boards out, which I could of induced when I took my neg terminal off to clean.
Old 01-14-2007, 03:56 PM
Thanks copyman for the info, atleast now I will know where to look if mine starts up again. Rc
Old 01-15-2007, 07:49 PM
Copyman, find out anything? I priced the module at a dealership near me, quoted $185. dollars. Let us know if that was the the problem.
Old 01-16-2007, 08:31 PM
I replaced the module today and the 4 wheel drive works like good
Old 01-17-2007, 09:02 PM
Thanks, I replaced my today also, so far it works also!!! Yahooooooooo! I can gon on the ice now being I got 5". Later, Thanks again.
Old 01-18-2007, 09:03 AM
do you guys have the part number for the 4wd module?
Old 01-18-2007, 06:53 PM
Far as I can figure P/n 1L5Z*7E453*AC Module - TRANSFER SHIFT CONTROL. I also had the Transfer case elect. motor replaced P/N 1L5Z*7G360* $308. Mine is a o2 sports trac 4x4.
Old 01-25-2007, 12:50 PM
neemeth neemeth is offline
neemeth is starting off with a positive reputation.
I am having the same problem and will be replacing my module this weekend. I was quoted 185$ for the module as well.
You stated that the module is behind the glove box. Is this difficult to get to? Does the dash need to be removed or can it be accessed from the passanger footwell area?
4X4 Low works no 4X4 high Slapshottr Excursion - King of SUVs 1 12-21-2016 06:52 AM
4x4 high light not on Zach Jones Offroad & 4x4 1 10-26-2016 07:23 AM
2001 Explorer Sport 4x4 problem Shannon Duggan Explorer, Sport Trac, Mountaineer & Aviator 0 09-07-2015 02:09 AM
stuck in 4x4 low pmrfin Explorer, Sport Trac, Mountaineer & Aviator 3 10-31-2014 12:44 AM
4wd won't engage 4x4greenbeast 1997-2006 Expedition & Navigator 17 05-22-2014 01:10 PM
Tags
1l2z7e453, 2002, 4wd, 97, drive, explorer, ford, issues, power, problem, problems, shut, switch, trouble, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
