239 differences from F1 to F3
I just got my '51 F3 home and the 239 will run but it needs a lot of tuneup help. Looking through the catalogs they list F1/F2 then F3 separate for stuff like plug wires, fuel line from tank to pump, stuff like that. I need both those items and more, I am pretty sure there wouldn't be a difference but with my luck there is and I'll order the wrong stuff. I also need new belts, would someone like NAPA happen to carry them?
Yeah I just searched their site and they list F1-F3 as the same for the plug wires and belts. The picture in LMC shows the fuel line just like on my '48 I6, it goes to the front P. side, on my '51 V8 the pump is on the rear D. side. I think I'll probably just buy some tubing and make my own for a lot cheaper.
I've been on the computers at the NAPA Store (several hours), you can put in almost any part number as far back a Model A's and it will show cross ref numbers. It will also show cross use, i.e. a Model A Fan belt will fit a 54 Dodge, 56 Rambler, ^2 Studebaker. (Made that up)
They may not carry the part but they can get a bunch if info on them.
Ana they do carry alot of the Flathead stuff.
I wonder, did frame length change from f2 to f3? I haven't really seen any f3s to know, but did any of them have pickup beds or anything? If not, that would explain why the different part numbers for things like brake lines, fuel lines, and wiring (except stuff strictly limited to the engine compartment) I guess I'm just thinking out loud. By the way, need any help w/finding part numbers or do you pretty well have that under control?
F-2'/F-3's both had an 8 1/2 ft bed version, I believe the main diff were in the springs, maybe brakes. Both used the same Frame (Longer than the F-1).
Over the years part numbers have changed, as newer models were developed the # superceded the older one. Say the front outer wheel bearing for a 48 F-1 was the same as the 56 F-100, the parts store may only list the 56 # but when you look on the computer or in their book it will say "Fits 1948 - 1956 F-1 - F-100.".
jeffh
11-11-2015 11:58 AM
AndeyHall
1999 to 2016 Super Duty
07-15-2013 07:42 PM
F-100CustomCabTBC
07-02-2013 10:22 AM
F-100CustomCabTBC
11-19-2008 05:26 PM
