302 H.O. Swap into my '91 F150
My ole 5.0 is getting tired. I was wondering if anyone has ever taken a Mustang 5.0 HO and made the swap. If so what is involved. I have already talked to Jegs and Hyperteck and obtained the part number for the Power Module needed for the computer but how 'bout the other things? Is this a direct bolt in? Will my headers from my 302 fit the HO? Would I need to install a higher pressure fuel pump? Etc....????
If not does anyone know where to find out this info?
Thanks
Tim
Thanks
Tim
A lot of what you have to do depends on the model year difference. I have an 87 F150xlt with an 89 Lincoln HO motor, it was pretty straight forward, very few changes required. (My nephew did the swap, I bought the truck from him after). The electronics are basically the same. If you went with a newer 302 HO, you'd have lots of changing to do.
on
It's a direct bolt in with the truck oilpan and pickup, and truck intake. You don't need the chip, FPR, or fuel pump, and the truck computer and wiring harness will drive it fine. The only other thing of note is that the HO firing order is different than the truck, but all you need to do is keep the HO plug wires routed as they come.
And since I have talked with them, I think I have decided to kill the conversion idea and rebuild mine. I am going to install aluminum, higher compression heads; a mass-air conversion kit, and cam. Jim from Ford Performance hooked me up with a guy that can grind me a roller cam to my specs per my application (for those that didnt know, as I, this block of mine is the same as the HO and will accept a roller or flat-tappet cam). And with these mods I should be pushing 390hp.
Thanks Guys
Originally Posted by 98powerstang
Where are you going to get your Mass Air Conversion kit? What all mods are you going to be running to get 390hp?
http://www.fordracingparts.com/parts...tKeyField=1179
The guy at Ford Racing Performance told me today with the mass-air, with the roller cam profile I chose (part #M-6250-Z303), the higher compression "Z304" heads(which with the flat tops will bring it up to 10:1) and with the headers he estimated the hp to be around 390hp w/360 ft/lbs of torque. If I had went with the 9:1 compression it would ran at 360 hp w/330 ft/lbs of torque
WOW that cam has a HUGE lope. Thats going to be hard as a daily driver dont you think. Thats messed up when I called FRPP they told me they didnt make those. You going to do anything with the pistons. With that cam you will have piston to valve clearance issues.
You'll need an intake other than the stock truck intake then, it won't play nice with those parts. I'm thinking something with significantly shorter runners... Holley Systemax or the like.
I am sure that Cam will work since he is a builder he would know. To me though for a daily driver that is a HUGE cam. Look up the Ford Racing Z303 cam on the net. Its the BIGGEST cam that Ford makes called the Camzilla. Most people use the E303 cam on a daily driver truck. Either way when its done I would LOVE to hear that thing. Your truck will move to the lope of the cam lol.
Thanks for bringing that to my attention
Here are the profiles for anyone inetrested:
M-6250-E303 1985-95 Hydraulic Good idle quality. Excellent low- and 2500 5500 282° 282° 0.498" 0.498"
302 with mid-range power. Power through 6000 RPM.
Emissions legal with 5-speed manual trans
Works well with automatic transmission. Great for super chargers.
M-6250-F303* 1985-95 Hydraulic Slightly rougher idle than E303. More 2800 6000 288° 288° 0.512" 0.512"
302 with Roller Roller mid-range and top-end power than E303.
Tappet Cam Tappet Great for super chargers. 5-speed manual transmission recommended.
M-6250-B303* 1985-95 Hydraulic Fair idle quality. Good low-end torque. 3300 5100 284° 284° 0.480" 0.480"
302 with Roller Roller Significant top-end horsepower above 4000 RPM. 5-speed manual transmission recommended.
M-6250-X303* 1985-95 Hydraulic Ultra high-performance camshaft. 3500 6200 286° 286° 0.542" 0.542"
302 with Fair idle quality. Big time torque and horsepower maker—up to 6200 RPM. 5-speed manual transmission recommended.
M-6250-Z303* 1985-95 Hydraulic “CamZilla” the biggest and baddest camshaft 3500 6500 290° 290° 0.552" 0.552"
302 with Ford Racing offers Fair idle quality. Big time torque and horsepower maker—up to 6500 RPM. 5-speed manual transmission recommended.
I drove a 84 Mustang with the E303 Cam Saturday and it was nice. Take off was alittle different for me I have never driven a 5spd with a Cam. Are you ordering the parts for your motor yourself or you having the guy order them directly from Ford? If you are ordering the parts yourself and decided to go with the E303 Cam let me know. I have a new E303 Camshaft kit
Kit Includes:
Ford Racing camshaft
Ford Racing hydraulic-roller lifters
Mr. Gasket cam change gasket kit
Permatex engine assembly lube
Has everything for the install.
Kit Includes:
i got questions, 1st what trans? if your not running a e4od, go the the junk yard and pull the harness pcm and needed sensors of a 89+ 5.0 mustang , or 91-93 tbird-cougar with a 5.0. they are aod cars and are mass air and 5.0 ho . this will be a minimal effort & cost for making this truck run right. the ford racing stuff is great but i always found the price on their mass air kit to be a little much for what you get. the cams you cant go wrong, i persoanlly think the e303 is too little cam for such a heavy truck . fuel pumps. depends how far you want to go , i personally would do 190 lph or higher . these should supply enough fuel as long as you stay normally aspriated. dont forget injectors too. i would minimal of 24lb .
Kit Includes:
Kit Includes:
