Spark Plug gap and torque 239
Old 01-18-2007, 01:37 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
As the title says what are the gap settings and the torque on the plugs for my '51 Flat8?
I pulled one plug and it was not very tight.
Old 01-18-2007, 06:20 PM
kotzy's Avatar
kotzy
kotzy is offline
Per 49/50 truck manual old H10 plugs were .025 to 028. Plugs were tightened to a torque reading as follows with a new gasket, 24-30 ft. lbs.
Old 01-18-2007, 06:55 PM
galaxie641's Avatar
galaxie641
More torque than I would have figured thank you.
Old 01-20-2007, 10:55 AM
dffay's Avatar
dffay
dffay is offline
Could that be INCH pounds?
Old 01-20-2007, 11:00 AM
dffay's Avatar
dffay
dffay is offline
Bishop's book cites 24-28 foot lbs in cast iron heads. If you have aluminum heads it would be less. Both should get some anti-seize lube on the threads.
Old 01-20-2007, 02:42 PM
kotzy's Avatar
kotzy
kotzy is offline
My info comes from a Ford service manual by Ford dated May 1 1950. You have to remember you are crushing a copper and asbestos gasket which had a direct influence on the heat transfer from the sparkplug shell to to the head. That is what people don't think about even today with the tapered seat plugs, if they are not tight enough the plug becomes a hotter plug then someone thought they installed. I don't know what they have substitued for the asbestos today,
I'm sure someone jumped on the plug makers to get it out of there.
Kotzy
Old 01-20-2007, 04:13 PM
galaxie641's Avatar
galaxie641
I was surprised, the plugs in it seemed really loose. The plug box said something about tightening to either a 1/4 or 1/2 turn. Anyway got the new ones in and the engine runs even better now that it has new plugs and the original wires, yes I said original, are gone. All but 1 plug were still within spec, one was under .020, probably close to .010 rest were around 025.
dobenator
12-06-2016 12:06 PM
Shernius
1997 - 2003 F150
17
04-01-2015 09:05 AM
abelmoreno
07-03-2009 12:25 AM
Trevor1
12-07-2006 11:32 PM
elstx
16
09-18-2003 05:17 PM
Quick Reply: Spark Plug gap and torque 239
