A4WD Issues - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
A4WD Issues
Old 01-05-2007, 12:22 PM
topfisherman's Avatar
topfisherman topfisherman is offline
topfisherman is starting off with a positive reputation.
A4WD Issues
I just got done replacing the transfer case on my Dad's 2000 Expy because it was stuck in 4Hi. After it was done, I took it on a short drive around town and everything seemed ok, it drove fine and the 4WD finally worked. The problem is as soon as I took it on the highway there was a shudder that felt like the truck was trying to shift into 4WD. I pulled the fuse for the A4WD and took it on the highway again and there was no more shudder. Any ideas? Could one of the sensors for the A4WD be messed up? Is there anyway to test them? Or could the control unit have problems?
Old 01-06-2007, 01:08 PM
ToolTime's Avatar
ToolTime ToolTime is offline
ToolTime is starting off with a positive reputation.
T-Case shift motor, or one of two wheel speed sensors located in the t-case. I'm probably preaching to the choir here, but make sure the tire sizes are the same all around, and air pressures are within a few pounds of one another.
Old 01-06-2007, 07:58 PM
Quote:
See, now how close do those have to be? The truck needed two of the tires replaced because of a flat, so now the front tires are brand new and the rears have 75% of the tread gone.
Old 01-06-2007, 08:25 PM
EagleDakota EagleDakota is offline
EagleDakota is starting off with a positive reputation.
I had the famous "rumble" when turning from a stop. tried everything. The tires had been on the truck and not properly rotatedm even though there was lots of tread left. When I replaced the tires, the problem went away and has not come back in 20,000 km. When replacing tires on a 4x4 I have been told that it is best to replace all at once. It is all about rotation speed and I would say that if you are looking at 2 old tires with 75 % tread gone and two new tires, you are going to experience some complaints from the system.
Old 01-07-2007, 11:14 AM
ToolTime's Avatar
I'm not sure, but I would guess it is close regarding the new tires and the old ones. Did you replace your speed sensors when you rebuilt the case? Just thought of something; try airing down the newer tires a bit, like tricking the system into thinking all tires are the same, and see if things change. Keep us posted!
Old 01-10-2007, 02:41 PM
zmock8's Avatar
zmock8 zmock8 is offline
zmock8 is starting off with a positive reputation.
I am having a similar problem. When the tires spin out in A4WD and then tries to engage 4WD, it then proceeds with a clunking sound that is trying to engage and disengage the 4WD. I just dropped the rig off at Ford and the tech said his first thought is a spring in the transfer case, but I will know more in a few hours.
Old 01-10-2007, 06:32 PM
No, we didn't replace the sensors because we just picked up a used case from a 2002 Expy and threw it in. I'll have to try airing down the tires and see what happens. It would be amazing to me if that would fix it because I couldn't believe the system could be that sensitive.
I'm really starting to hate the A4WD on these trucks.
Old 01-11-2007, 09:14 AM
zmock8's Avatar
I got the rig back and they said that the tires were so off from not being rotated that it was creating the 4WD to engage and disengage and that new tires were the problem. I am putting on new tires today and I will let you know what I find out.
Old 01-11-2007, 09:19 AM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
I could believe that the 2 new tires are the problem. With these trucks, you need to replace all 4 tires rather than just 2 at a time like some other vehicles.
Old 01-12-2007, 07:00 PM
Quote:
Please.
Old 01-14-2007, 10:19 PM
rockstate45 rockstate45 is offline
rockstate45 is starting off with a positive reputation.
zmock8, first off, what year is your Expy? Over here in the midwest, it's snowing quite a bit and I have to put mine into A4WD to get around. I drive a '98 and I've noticed for quite some time, that when I put mine into A4WD, dry pavement or not, whenever I accelerate at anything more than a leasurely gallop the transfer case seems to "jerk" the car along. Quite annoying after a while but I've never had any problems getting out of 4wd. My brother did have a problem once getting out of 4LO but probably because of his stupidity.
Anyway, do any of you guys have ideas as to what could be wrong? From my experiences, it has no effect on how well the A4WD works, which is pretty solid. Can't beat doing some A4WD donuts though
Thanks again,
-rockstate
Old 01-15-2007, 11:58 AM
zmock8's Avatar
Well, the tires took care of the problem. Now when it slips in gravel or anything and then right back on to dry pavement, it doesn't continue making the clunking sound going in and out of 4WD. It just goes in and then comes out like it should. I guess the tires were the trick!!!!!!!!
Old 01-15-2007, 05:11 PM
Hmmm... Looks like I might have to replace the other two tires so they are all new, even though I really don't want to.
2007 F-150 Transmission Shudder when Shifting poobah47 2004 - 2008 F150 5 01-11-2014 09:34 PM
Shuddering... at highway speed BruceJeremy 1997 - 2003 F150 1 06-19-2013 10:55 AM
2003 Expedition 2WD Transmission Whine/grind dstrahm Expedition & Navigator 3 08-26-2011 06:50 PM
Shudder problems subford 1987 - 1996 F150 & Larger F-Series Trucks 6 06-12-2007 01:23 PM
Why has my van started shuddering? aerostargal Aerostar 15 12-10-2003 01:02 PM
Tags
1997, 1998, 1999, 2000, 4x4, a4wd, disengage, drives, expedition, explorer, ford, forum, fuse, jerks, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
