Under Dash A/C Units - Ford Truck Enthusiasts Forums
Old 01-05-2007, 04:26 AM
75 SuperCab 75 SuperCab is offline
75 SuperCab is starting off with a positive reputation.
Question Under Dash A/C Units
I was wondering if there are many trucks out there that have under dash a/c units installed in them? Was there ever an optional under dash type of a/c unit offered by Ford? Do these units work any better than the "in dash" type of after market systems? Does anyone know if this kind of a/c system can use the newer type of freon?
Any kind of information that anyone can provide about these units, would be greatly appreciated!
Thanks,
Larry Bailey a.k.a. "75 SuperCab"
Old 01-05-2007, 04:35 AM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
Maybe do a search this forum for "underdash A/C". I had brought up this topic along with other FTE users and found some helpful information.
There was a dealer underdash A/C unit installed in these trucks, but it is not longer made. You would have to find one out of a donor truck.
Vintage Air (vintageair.com) makes an underdash unit that looks good.
Old 01-05-2007, 07:16 AM
scottie2hottie's Avatar
scottie2hottie scottie2hottie is offline
scottie2hottie is gaining momentum as a positive member of FTE.
Somebody on here has a late 70's pickup with one and says it works great. Cant think of who it is though.
Old 01-05-2007, 08:27 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Lightbulb
From 1955 through 1964, all the Ford* passenger cars used hang on air. Both as factory and dealer installed. There are several styles. In the early days there was Polar Aire, and Select-Aire. The only difference was in the design of the case, with the Polar-Aire being white plastic, and the Select-Aire being chromed.
The last Ford trucks that used factory installed hang on air were the 1972 models. The slim line case extended under the dash about 20 inches. The inexpensive versions was all plastic, with the better units featured chrome with a wood grain applique. Ford still offered dealer installed hang on air into the 1980's.
The early a/c hang on units are rarely seen today, and were a (mostly) a dealer installed option. The a/c units that were optional for Ford cars could and were installed on Ford trucks.
1957 was the first year one could order factory air installed from the factory...on cars only. These units were in-dash, with the registers at the front of the dash, taking the place of the windshield garnish moulding. However they were expensive, and not very efficent, so Ford cancelled this option in 1959. I believe that it was in 1967-68 that Ford first installed factory hang on air on the F series trucks as an accessory.
*Lincoln Continentals had in-dash a/c as a factory option in 1956, and Mercury first offered in-dash air around 1964.
Ford continues to offer dealer installed in dash a/c to this day.
Old 01-05-2007, 10:20 AM
buzzbait65 buzzbait65 is offline
buzzbait65 is starting off with a positive reputation.
this guy says he has in dash and under dash units for our trucks
http://www.rainbowproductsonline.com...&B=Home%20Page
Old 01-05-2007, 03:06 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Old 01-05-2007, 05:43 PM
flcracker9 flcracker9 is offline
flcracker9 is starting off with a positive reputation.
[QUOTE=buzzbait65]this guy says he has in dash and under dash units for our trucks
http://www.rainbowproductsonline.com/index.html?token=1961526216-278146363-1408425120&A=1&B=Home%20Page[/QUOTE]
I see this guy has a slim line under dash for 67 - 72 ford pickups. Do they have the same dash configuration as the 73 - 79?. Common sense tells me no, or they would be advertised as 67 - 79?
Old 01-05-2007, 05:59 PM
The 73-79 Ford Truck vintage air unit has to be made up from generic parts.
Old 01-05-2007, 06:40 PM
[QUOTE=flcracker9]
this guy "SAYS", is what i said, call him, he says he has a unit for 73-79 trucks, but i appreciate the unresearched sarcastic comment to my post......... thank you
Old 01-05-2007, 06:51 PM
[QUOTE=buzzbait65]
Quote:
I wasn't trying to be sarcastic, I was just asking if anyone knew if the dash configuration on the 67 - 72 was the same as the 73 - 79?. If it is, the unit looks interesting. I only used the quote "common sense" to show my lack of knowledge between the 2 different body styles. He shows the picture for many different trucks, the only close to ours was the 67 - 79 unit.
Old 01-05-2007, 07:30 PM
I had the original york compressor style factory in dash a/c, and was never impressed with it, so i went to a fridgidaire lincoln style comp with all new components, it was cold but i still wasnt impressed with the airflow (bad ducting design i suppose), that is how i came across rainbow air, he says he has a unit that has heat , cold , defrost and it fits in the dash of the 77 supercab i am putting together, i had a regular cab so i know i will need more airflow
Old 01-06-2007, 09:20 AM
The first Lincoln's with a/c used a Lehigh compressor...it's a huge cast iron V2.
Nowadays, with R12 Freon hard to find and expensive, you have to go with something like a Nippondenso compressor, which looks fugly as hell under the hood.
Old 01-06-2007, 09:58 PM
Yogis1097's Avatar
Yogis1097 Yogis1097 is offline
Yogis1097 is starting off with a positive reputation.
Let me start this off by saying I have no stock in Vintage Air and I'm not pushing their unit on anybody. I did, in my opinion, a LOT of research in underdash A/C units before I bought one. My truck didn't have factory air and I chose to go with an underdash unit rather than hit the junkyard and find a truck with factory air. I bought a Vintage Air unit and have had no probelms. The only negative factor is that they are quite pricey. I live in Central Florida and I'd rather spend the summers in my truck riding around with cool air than rolling the windows down and hoping it does not rain. Stay safe guys.
Old 01-06-2007, 11:36 PM
The underdash units are pricey, but take these things into consideration.
1. installing factory A/C into a non A/C truck..... A LOT OF TIME, plus you have to get a donor truck. Could end up being a HUGE project. Also, unless given to you, you need to spend some money on a donor truck.
2. Having a dealer install A/C into your truck. Probably going to be more expensive. Unless you work at the dealer and can get the parts for nothing.
3. If you want A/C and want a more easy job of doing it....buy the underdash A/C unit.
Really, It can come down to time. Do you really want to tear your current trucks interior down along with a donor truck's interior? Plus, cut that big hole in your non-A/C cab? But, sometimes the bigger jobs are more fun. Who wants to take the easy way out?
Old 01-07-2007, 03:10 AM
wayneasbell wayneasbell is offline
wayneasbell is starting off with a positive reputation.
What about Classic Auto Air out of Tampa? Has anyone bought or used there products? I live in FL as well and the heat is too much. My next big project is A/C. I have a quote for ACME brand under dash, but I don't know much about it. I was told ACME will put out 35 deg F. That would be nice in FL!!
Air conditioner crewchief99 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 06-11-2014 12:07 AM
Adding A/C to truck daddylee100 1967 - 1972 F-100 & Larger F-Series Trucks 4 11-15-2013 09:31 AM
Anyone have any experience with aftermarket A/C units?? SVTDriver97 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 09-18-2013 10:47 AM
AC for 1972 F100? gabbagabbawill 1967 - 1972 F-100 & Larger F-Series Trucks 20 03-18-2013 11:53 AM
Cheaper A/C system? reed1951 1948 - 1956 F1, F100 & Larger F-Series Trucks 29 08-02-2012 03:05 PM
Tags
1955, 1957, 1959, 1964, ac, aire, dash, f100, ford, pickup, polar, select, tbirds, truck, underdash, units
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
