Coolant Leak !!!!! Please Help ?? !!!
I went out the plug my block heater in tonight and i noticed a puddle under the truck , i went inside an got a flashlight , i have coolant leaking from the crankshaft seal.. this to me seems very bad ? is this common ? do you have to pull the motor to change this seal ? is it a big job ?
Well i got a little lucky , my leak is just coming from the metal tube that bolts on to where the thermost is . So i tool it off and the rubber ring was ruined so i bought a new one , ford said they don't sell a gasket for between the metal tube and the water pump, and it was siliconed .so i cleaned all surfaces and re-siliconed it... leak went away for about a day then came back same spot as before , is there something better to use then silicone ?
Masterc that metal piece you are referring to is VERY easy to bend. I had the same problem when I changed my water pump. Make sure that the flange is perfectly flat. I had to lightly tap on it to get flat. I used the back of one of my vises to get it flat. When you reinstall that piece the rubber o-ring will seal if you do it carefully. You can't tighten the bolts really tight. Snug one down then another and then the last one. Don't tighten them nut bustin' tight either. They need to be snug only. If you tighten one too much you'll have a leak again (ask me how I know). If your water pump starts leaking from behind the pump up against the block you should replace the pump while your there. That water pump has a rubber o-ring instead of a gasket like alot of other vehicles have. To get it to stay in place put a tiny amount of petrolium jelly on the rubber o-ring while installing the new water pump. You will also need to get a hold of the fan/clutch tool to remove the fan. Autozone has them on loan a tool program. I just bought one though. I go with the theory if I need it more than once I need to buy that tool. Good luck I hope this helps ya.
mdbiofuels
05-31-2012 11:22 PM
GoCamping
17
01-11-2010 07:13 PM
newt79-99
04-18-2006 01:27 AM
