Transmission Issues FX4 / 04
Has anyone had a clunk or jerking feeling when letting off the gas then accelerating. This occurs at highway speeds and low speeds. It feels like the limited slip but in a straight line? I already greased the drive shaft, so I am just curious if anyone else has had this problem.
My 04 FX4 does the same thing. Ford will tell you that it's "normal". I don't know anyone with an 04 or 05 that doesn't have this clunk.
CMOS
Originally Posted by InstantGrits
I had the same issue. The dealership told me there was a TSB about a shim changing the angle of the driveshaft. They installed it and NO MORE CLUNKS!! I was amazed but it worked. Make your dealer look at all the TSB's about the noise, there are a few.
Do you have a long or short bed truck?
CMOS
Originally Posted by 04 FX4 Lineman
My 04 has no clunking is a SC shortbed 6'5 bed if it did it would be in dealer or gone!!
I would personally label this noise as a "slam", not just a clunk. If I drive 45-50 then coast down to 25-30, then moderately acellerate the tranny really slams back into the lower gear.
I guess I will try to take it to the dealer and see what they say.
Does anyone have the TSB with regards to this noise?
CMOS
