Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids and Mileage
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-04-2007, 03:50 PM
pjlandry is starting off with a positive reputation.
Propane tank size
Hi Guys.
I run a E150 with a factory propane 4.9l (Engine code 9)
I've got a 100 litre tank on my van, and it only gives me about 350km. (~250miles) Slowly working my way to figure out the low milage.
Can I replace with a larger or add a secondairy propane tank so I can have greater range? What's the largest tank I can "legally" mount?
Thoughts?
Thanks.
-Pauli
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-09-2007, 12:45 PM
MrBSS is starting off with a positive reputation.
I am not familiar with your particular set-up, but it is not unusual for the mileage to be lower when running propane. This is particularly true if yours is bi-fuel or basically a gasoline vehicle which has not had major modifications (compression ratio, timing, etc.) to take advantage of propane's characteristics.
I don't know what size tank would be legal there, but if you have a company who services propane lift trucks (as in a freight terminal), they could probably supply another tank and tell you what you could do.
  #3 (permalink)
Old 01-15-2007, 04:12 AM
roger dowty is gaining momentum as a positive member of FTE.roger dowty is gaining momentum as a positive member of FTE.
not sure size is the issue. has to be the right dot tank design. I bout a 80gal for my truck and plan on running a couple 30-40 gl tanks under the bed eventually just for long trips.
Propane needs engine compression. It's well over 100 octane but lower btu. running higher compression gets more out of the fuel w/o risk of detonation due to the octane.
__________________
'77F1504x4, '75 f250crew4x4, '79 Bronco 429, '83 bronco, '72 Torino with 351cj, 70 1/2 falcon, 75 stangII. all projects, 2 on the road. One pissed off wife!
  #4 (permalink)
Old 01-18-2007, 02:06 PM
1978Crew is starting off with a positive reputation.
how do you plan to switch fuel delivery between the different tanks? Are forklift tanks DOT approved for motorfuel on street vehicles?
__________________
1978 F250 2WD Crew Cab 351M/ C6
  #5 (permalink)
Old 01-18-2007, 03:05 PM
Haven't really thought that far yet. Just trying to figure out what my options are. Maybe someone here could make a suggestion!
-Pauli
  #6 (permalink)
Old 01-19-2007, 02:06 AM
forklift tanks are for off road use. Not certified
__________________
  #7 (permalink)
Old 01-25-2007, 12:12 PM
I believe that the supplier for the fork lift trucks could probably give this guy strong enough tanks for the road. Frankly, if he needs to go through certification from all the government bodies, he can't afford to do this. Well, it sounds like he's not in "the land of the free", so maybe he could.
  #8 (permalink)
Old 01-26-2007, 12:14 AM
I'd use the tanks in a heart beat...but would also know that I might pay for it someday...but probably not. It's good to know which rules your breaking
__________________
  #9 (permalink)
Old 01-26-2007, 09:55 AM
i am looking for something to use to get my conversion going soon. I can wait to find the right tank for the right price.
__________________
  #10 (permalink)
Old 01-27-2007, 11:03 PM
It seems the best bet is to find one locally- they cost so much to ship. I nearly ended up with a 120 gal for a song but didn't follow up. would rather have that than my 80. you can pick them up for cheap it seems...just gotta be on the lookout.
__________________
  #11 (permalink)
Old 01-29-2007, 11:01 AM
thanks, I am on the lookout. But don't want to wait to get started with the conversion.
__________________
  #12 (permalink)
Old 02-02-2007, 10:56 AM
fraso is starting off with a positive reputation.
The largest tank you can legally mount on your truck is an ASME (and not DOT - lift truck) tank that can be securely bolted down onto your vehicle. Sleegers and Manchester commonly make bed-mounted tanks designed for full-size pickup trucks and the largest tanks made are the 20x60 (218L / 57.6 USG) and the 24x60 (310L / 81.9 USG). You will need to check the space between the cab and the wheelwheels on a crew cab as the 24x60 may be a tight fit.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
