Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 01-04-2007, 12:43 AM
57trailer 57trailer is offline
Garage is empty, add now
57trailer is starting off with a positive reputation.
7.3L IDI diesel with biofuel
I'm almost ready to buy a very clean 1992 F250 7.3L diesel (2 tanks), but I want to make sure I can burn biodiesel without too much fuss. From previous threads it looks like I can do it. I have a biodiesel station down the road so I hope it works!! thanks for any advice.
  #2 (permalink)
Old 01-04-2007, 07:43 AM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Quote:
Welcome to FTE The best FORD site on the web!
You are right, you can use Biodiesel in your truck. Your FORD is gonna love it
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 02-03-2007, 03:58 AM
Cool6.9DieselGuy Cool6.9DieselGuy is offline
Cool6.9DieselGuy is starting off with a positive reputation.
can you run 100%biodiesel in an idi 6.9/7.3 or just a certain percent? is there any type of maintance you should do besides the norm if you run this stuff often? what about in colder climates?
  #4 (permalink)
Old 02-03-2007, 05:43 AM
1935 Ford pickup
Quote:
Yes, you can use any blend of bio in your truck. From B-5, through B-100. No mods or extra maintenance required! Where you live you won't want to run more than B-20 in the winter tho because bio has a gelling issue below about 30 degrees. If you use a blend higher than B-20, you'll find it will clean out the fuel system and may plug the fuel filter, so I would carry a spare. Once the system is cleaned out that will no longer be a problem, and you can go back to normal filter change intervals.
Are you going to be using commercial fuel, or make your own? I've been making my own for over 3 years now and will never go back to Dino-diesel! You will find that with any blend over B-20 that your truck will run smoother, quieter, with no smoke, and smell MUCH better!.
__________________
  #5 (permalink)
Old 02-04-2007, 01:19 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
If it's a 1992 you may have to frplace some fuel lines and seale.
I think Ford was still using rubber for those components at that time.
If you replace use Vitron.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #6 (permalink)
Old 02-06-2007, 12:38 AM
well I definitely dont know anything about making my own, I've heard you can strain used restaurant frying oil... I wish I knew about that and had a diesel when I used to work in the restaurant bussiness. What are some of the methods for making it yourself? What are the advantages? I've heard you dont save that much money if you make it yourself but that was probably not relavent to taking used oil from a restaurant but instead maybe buying cooking oil in bulk and then adding stuff? Sorry if I'm not on the right track but I dont know much at all about this and maybe it would be an advantage to me being that the 6.9 can run on bioDes w/out any mods.... hoping it might save me some $$$ more than anything if I can clean this stuff out from restaurants. You seem like an expert, let me know about this stuff, thanks from Drew
  #7 (permalink)
Old 02-06-2007, 07:43 AM
1935 Ford pickup
Drew, you can get up to speed on everything biodiesel related here: http://www.biodieselcommunity.org When you've checked out that site come back here and search the posts in this forum, and you'll find many people who've started making there own bio. It's really very simple. My cost to make bio runs about $.50 per gallon but I buy my supplies in bulk. Most people report that they can make it for less than $1.00 a gallon. Welcome to our biodiesel forum, and if you wish to make biodiesel the people here are always willing to help. We'll have you making your own fuel in no time
__________________
  #8 (permalink)
Old 02-07-2007, 12:02 AM
Drew, you can get up to speed on everything biodiesel related here: http://www.biodieselcommunity.org When you've checked out that site come back here and search the posts in this forum, and you'll find many people who've started making there own bio. We'll have you making your own fuel in no time
well I went to that website and it looks like it's jam packed w/ info on how to make this stuff... you were talking about b-5 through b-100 and not to run 'more' than b-20 this time of year, i'm guessing 'more' would be b-20 through b100? what is it about fuels higher than b-20 that will 'clean out' your fuel system and plug a fuel filter?
are you sure there are absolutely not mods I 'have to' make to my 86 f350 6.9L to run the bioDiesel? Well how bout if I were to run a grade higher than b-20 this time of year... what kind of mods could/should I make? I'm guessing that grades higher than b-20 are cheaper to make also right(maybe not?)?
$0.50-$1.00/gallon?!?!? OK YOU SURE CONVINCED ME OF THE ADVANTAGES! I'll be at that website all night tonight studying this stuff, i'm sure I'll be answering some of my own questions by the end of the night! HEY MAN THANKS A LOT!
  #9 (permalink)
Old 02-07-2007, 07:46 AM
1935 Ford pickup
If you use blends higher than B-20 it will scour out all the "crud" that dino-diesel has left behind. Biodiesel is a very good solvent [It is what I use now in my parts washing tank!]
You will have to replace the short rubber fuel lines on your "86" tho. Ford didn't start using synthetic fuel lines until after 1991. Biodiesel will soften natural rubber.
My cost to make pure [B-100] biodiesel is around $.50/gal. During the winter I use B-80 [80% biodiesel-20% dino-diesel] to avoid the gelling problems that b-100 has.
__________________
Tags
73, 73l, bio, biodiesel, burn, diesel, f250, ford, fuel, idi, make, oil, run, safe, vegetable
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
