1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Lets see pics of all ur lifted super dutys
Old 02-14-2014, 08:46 AM
Will Bite's Avatar
Will Bite
Will Bite is offline
Done
4.5 Inch Rough Country
  #1262
Old 02-14-2014, 08:50 AM
Will Bite's Avatar
Will Bite
  #1263
Old 02-14-2014, 08:58 AM
Will Bite's Avatar
Will Bite
Before
  #1264
Old 02-14-2014, 09:32 AM
RxSd2013's Avatar
RxSd2013
RxSd2013 is offline
Well done Will!! Truck looks awesome!! nice stance!!
  #1265
Old 02-14-2014, 09:38 AM
Jigger2020's Avatar
Jigger2020
Jigger2020 is offline
Received 5,160 Likes on 1,689 Posts
Will I love it but I think you need ladder bars now
  #1266
Old 02-14-2014, 09:47 AM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is offline
Received 3,392 Likes on 2,089 Posts
Nice and clean looking stance Will, I like it.
  #1267
Old 02-14-2014, 10:41 AM
RxSd2013's Avatar
RxSd2013
RxSd2013 is offline
Originally Posted by GIGGER
WOW, she looks fantastic Rex, I love white truck but yers rocks.....Have you got pics of the Viair & horn setup, thx Gerry
I did my Viair 10007 install just like Epic did. I didnt see any reason to change a set up that I felt was already perfected. I am sure you have seen his installs. That dude is one of the main reason I became such a huge fan of FTE. Here is the link for those needing to see how to install a air compressor on your truck and run it off a up fitter. I say again, Hats off to Epic for this install!!
I did change the location of the horns from his video, as I wanted the horns out front. You cant see them at all unless you really look for them or crawl under the truck. They are a bit more exposed to the elements but I just didnt want them under my butt when I blow the horn LOL. I used a piece of flat bar (2"x1/4"). Drilled 2 holes in the flat bar to mount it under the truck where the bottom of the brush guard bolts to the frame. Drilled holes in the flat bar to bolt the horns blowing out either side of the truck. Drilled holes to mount the solenoid in the center of the two horns. Mounted the flat bar with horns and solenoid to the underside of the brush guard and simply ran the air hose from the compressor to the front. Total install (Air compressor and horns) was about 2 hours if your drinking beer while installing. Here is a few pics of the finished product. They work great and are plenty loud.
A pic from the front.
A pic from inside the driver's side fender well (you can see the horn in front of the tire) The other side looks just the same for the 2nd horn.
A pic from under the truck where the install is.
And of course the air compressor under the rear passenger door as Epic did his.
I hope this helps!!
  #1268
Old 02-14-2014, 12:35 PM
RedDevil460's Avatar
RedDevil460
RedDevil460 is offline
Rex the truck looks beautiful as usual, I can't get over how much I like it, haha. I love that brown and tan color. Those flares look great on it too. I like those horns. Did you use the same horns as the video? I like how those sound.
I was looking at getting these for my truck eventually, but I kind of like the ones you have now too.
http://www.assuredautomotiveproducts...m1plqscsfapp06
Will that lift looks great, its like a completely different truck. I love the stance!
  #1269
Old 02-14-2014, 01:40 PM
RxSd2013's Avatar
RxSd2013
RxSd2013 is offline
2 Single Trumpet Big Rig Semi Truck Air Horns | VIAIR 150psi Kit
Thanks for the complements. It really does mean a lot to get such great revues after putting in so much work on these trucks. One of the main reasons I love this place is the positive attitude and the willingness to be helpful from everybody here.
Yes I felt that Epic did so good on his video install, that there was zero reason to try and reinvent the wheel. If something works why not stay with it.
Thanks again for the kind words!
Looking forward to the next mod!
  #1270
Old 02-14-2014, 06:05 PM
Will Bite's Avatar
Will Bite
Ladder bars on the list. Dumped alot into this beast this year so far. Studs and lift and tires. Now time to build account back up.
  #1271
Old 02-14-2014, 06:27 PM
Jigger2020's Avatar
Jigger2020
Right on Will, I thought you might say that, keep on truckin'
  #1272
Old 02-14-2014, 06:32 PM
Jigger2020's Avatar
Jigger2020
Thx for the air horn info Rex, yer right, Epic is great........
  #1273
Old 02-15-2014, 12:32 AM
Midnite1987's Avatar
Midnite1987
Midnite1987 is offline
I have they 4.5" revtek lift. What size tires are you running they look perfect size for that lift?
  #1274
Old 02-15-2014, 06:05 AM
gddyup's Avatar
gddyup
gddyup is offline
Will, how do you like the ride with the Rough Country kit? I'm looking into kits for my 08 5.4 for this summer and was gathering info. I'm looking for the 4"ish category and yours looks real nice.
  #1275
Old 02-15-2014, 07:22 AM
Will Bite's Avatar
Will Bite
Toyo AT2 in a 35/11.5. Next time I buy tires Im going to a 35/13 the tires are a little skiny.
Quick Reply: Lets see pics of all ur lifted super dutys
