97 f150 freeze plugs - Ford Truck Enthusiasts Forums
Old 01-03-2007, 12:22 PM
solomon solomon is offline
solomon is starting off with a positive reputation.
Can I get a quick run down of installing freeze plugs on a 4.6L?
Old 01-03-2007, 01:06 PM
scottie2hottie's Avatar
scottie2hottie scottie2hottie is offline
scottie2hottie is gaining momentum as a positive member of FTE.
Installing is easy- just find an old socket close to that large and tap them into place. Removing them can be another story.
Old 01-03-2007, 02:14 PM
where are they located, and do I have to take a bunch of stuff off to get to them?
Old 01-03-2007, 03:07 PM
They are set into the engine block....but you may want to seek assistance cause IMO they're not exactly a beginners job.
Old 01-03-2007, 03:40 PM
It's either the freeze plugs or the intake's cracked. There's water in the valley, and when I fill it up it drops the water pretty quick. Ends up dripping down from behind the block the best I can tell. I'm really hoping it's not the intake.
Old 01-03-2007, 04:27 PM
well generally the freeze plugs are on the side of block and generally you won't see leakage on the intake or that area if it's a freeze plug
Old 01-03-2007, 05:10 PM
ranger88a ranger88a is offline
ranger88a is starting off with a positive reputation.
Check the tube from the intake to the heater core on the rh rear of the intake. I've had a few corrode and leak.
Freeze Plug or block heater? idiabuse Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 11-29-2014 01:26 PM
block heater question CharlaineC 1967 - 1972 F-100 & Larger F-Series Trucks 1 10-29-2014 12:17 AM
351w Cam Freeze Plug Help Needed Pincheweddo Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 8 03-10-2014 09:08 PM
plug for dipstick tube FordmanShane FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 12-16-2013 09:15 PM
Freeze Plugs--Expandable or Press Fit? cyberdr2 1978 - 1996 Big Bronco 1 05-21-2010 03:59 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
