Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 05-15-2007, 03:55 PM
Skinsfan6 Skinsfan6 is offline
Skinsfan6 is starting off with a positive reputation.
Perhaps the longer stroke of the 2.9 was the cause of the dished piston head...this would give enough clearance between the piston and an open valve at TDC. Are you sure a Flat top piston would not hit an open valve. I'm pretty sure a dished piston is designed to maintain a certain stroke with enough clearance for valves when they are open, such as on the exhaust stroke.
  #17 (permalink)
Old 05-15-2007, 05:22 PM
rusty70f100 rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE. rusty70f100 is gaining momentum as a positive member of FTE.
This is a legitimate concern which would have to be adressed by the engine builder.
Lets take a look at some things here:
The link shows the stroke and deck height to be different between the 2.8L and 2.9L. Lets figure up deck clearance:
Deck clearance = deck height - (.5 * stroke) - rod length - compression height
2.8L deck clearance = 8.084-1.35-5.14-1.539 = .055"
2.9L deck clearance = 8.084-1.4175-5.14-1.461 = .0655"
Now then, a 2.9L with 2.8L pistons:
Deck clearance = 8.084-1.4175-5.14-1.539 = -.0125
So you'd be .012" above deck with 2.8L pistons. Which would probably be alright with a thick head gasket. Or, you could have the pistons shaved about 13 thousandths and have zero deck.
Then you could check valve clearance as has been done for years. Preassemble the motor and check! If you need valve reliefs, a machine shop can do it cheap. People do it all the time. I really doubt they'd be needed though. For one, the 2.9L cam probably doesn't lift all that much, and is nowhere near full lift when the piston is at TDC. Next, and the big factor, these are not wedge heads. The valves in these motors are at a 90 degree angle to the deck. Any valve relief would have to be a perfectly circular plunge cut. Really though, I dont think the valves at full lift would even contact the pistons at TDC. I dont think there's any interference there to begin with!
Also note that they have the 2.9L deck height wrong. It should be 8.084", not the 8.858" like the 4.0L block uses.
  #18 (permalink)
Old 05-15-2007, 07:54 PM
pud pud is offline
pud is starting off with a positive reputation.
110% i agree, and I thought I mentioned the 2.9L block height being off.
__________________
2004 Focus zts (60 miles a day round trip to work, stuff it)
  #19 (permalink)
Old 05-15-2007, 10:09 PM
Indeed you did!
However, I thought it would be good to mention it again just in case someone missed it the first time.
  #20 (permalink)
Old 05-16-2007, 02:45 AM
pud pud is offline
good idea, thats the only thing wrong Ive found on that page so far.
__________________
  #21 (permalink)
Old 05-17-2007, 11:53 PM
RacinNdrummin RacinNdrummin is offline
RacinNdrummin is new and has a neutral reputation at this point.
The 2.9 deck height is the same as the 2.8, its nearly the same block.
__________________
74/71 maverick grabber EFI HO (under construction)
05 ranger 3.0/5spd supercab
90 Bronco II, 4.0 swap (UC) 5-speed, 4x4, factory D35
6" lift 33's 8.8...
91 Mustang LX 5.0 Coupe (new engine being built now)
91 E250 4.9 c6 3.73
95 F-150/SB/SC 351w swap, 3.55, 4r70w (Dads truck)
  #22 (permalink)
Old 06-10-2007, 11:48 AM
390428cjt's Avatar
390428cjt 390428cjt is offline
390428cjt is starting off with a positive reputation.
heres another idea to check valve clearance at top of piston some have used alittle clay on top of piston rotate the assy on on cylinder and see what marks if any are left into top of piston by the valves kinda the same principal as checking bearing clearance.
__________________
390428cjt
FORD IS THE MOUNTAIN THE ROCK FELL OFF OF
1972 F-250 Camper Special 396 FE,C-6, Dana 60 4.10 limited slip.
1996 F-150 XLT 4X4 5.8 Heavy Duty Package
1982 escort 49k original miles 2dr hatch
  #23 (permalink)
Old 01-11-2009, 01:36 AM
eureka24 eureka24 is offline
eureka24 is starting off with a positive reputation.
I don't have the numbers on the top of my head but 2.8l pistons will work.
i recently built a flat top pistoned 2.9l. the numbers work out for the clearance and the compression is somewhere just north of 9:1.
Quick question.
why won't a 2.8L camshaft work in a 2.9L?
  #24 (permalink)
Old 01-12-2009, 12:07 AM
Old93junk's Avatar
Old93junk Old93junk is online now
Old and mean
1993 Ford F-250
Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold
Quick question.
Because the 2.8 has timing gears, and the 2.9 is chain driven.
__________________
FORCE IT!,IF IT BREAKS IT NEEDED REPLACED ANYWAY!
IF IT CANT BE FIXED WITH A HAMMER, ITS A ELECTRICAL PROBLEM!
Still bitterly clinging to guns and religion.
Dave
Oregon Assistant Chapter Leader: To join the Oregon Chapter, click HERE
  #25 (permalink)
Old 01-25-2009, 04:05 PM
Arctic Wolf's Avatar
Arctic Wolf Arctic Wolf is offline
Arctic Wolf is starting off with a positive reputation.
I know this is fairly old. And I dont know if anybody will answer but here goes. It was said that this idea works which is great. Ill be rebuilding a 2.9 in very near future and would like a lil more power out of it. Am I right to assume in doing this it would be my answer to getting the most I can get outa my 2.9? Ive never really built a hi po motor before so I really dont know of how things are done. If I could get a lil bit of a guide line into what parts I would need to build this Ill do it. Thanks
__________________
  #26 (permalink)
Old 02-09-2009, 08:43 AM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
If you have the money, Morana Racing (Canada) sells a 3.5L stroker kit for the 2.9. Otherwise, from my best guess, the only way to make this work is to use the 2.8 pistons and 2.9 rods. I have been doing some research on stroking both the 2.8 and 2.9. My main focus now is figuring out the rod lengths and deck heights (kind of stumbled upon this thread poking around) to see what may or may not work without a whole lot of machining involved, other than what is absolutely necessary. There are other threads in this part of the forum and one in the Bronco II forum related to this. The chart in a previous post doesn't take into consideration the BII / Ranger 2.8, which IS an identical bore size from everything I have found.
__________________
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4
'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD
(K&N air, all else is bone stock!)
  #27 (permalink)
Old 02-09-2009, 09:52 AM
Geez.. Talk about a fair chunk of change... 2500 U.S. dollars. Convert that over to Canadian dollars thats like 3051.50 And then add taxes onto that and shipping and what not. By the time your done. Your spending close to if not more than $5000. 0 Bucks on the motor alone.. And what for? So a guy with a slightly done up 5.0 can pound the crap outa ya? seems hardly worth it.
Thanks for the insight there Kernal. And as for answering my other post about the suspension as well thank you.
Could I be so bold as to ask you a few more QWuestions about our trucks? If I may.. Could you e-mail me and we'll take it off board.
Thanks.
Wolf_Pack-316@hotmail.com
__________________
  #28 (permalink)
Old 02-10-2009, 01:55 AM
Yeah, buying the parts, kits, etc. to do it with a 'pre-built' kit or short block is crazy expensive - which is why I have been looking into 'compatibility' using 'stock' Ford parts. Even with a slight bore and stroke, it's still not going to be cheap - but I personally am not after a street sleeper, just looking for a little bump in power for on the trails. I know, I know... why don't I just swap in a 4.0, right? I don't feel like snatching the motor and other pieces and parts only to rebuild an engine anyway before putting it in as I have noted issues from Explorer owners that have had their OEM heads crack, and really do not feel like doing all of the extra wiring work, etc. Not that I am not open to the 4.0 swap at this point, but I dare to be different sometimes
__________________
  #29 (permalink)
Old 02-10-2009, 02:25 AM
Actually I was talking to a guy that I know. And he says that a 4.0 l swap is a big waste of time. Its a huge headache that really isnt worth it. Just keep the stock motor and maybe boost its power up a bit like what you want to do. I think your onto a good idea.
__________________
  #30 (permalink)
Old 02-10-2009, 08:37 AM
pud pud is offline
the only thing that ever stops me from building a 2.9L is the fact that I would spend the money stroking it to come in under 4.0L. When I can buy a complete junked explorer for $500 and rebuild the engine and have everything I need to swap plus a more powerful engine and a better fuel management system.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
