can't get rid of code po604 KAM memory looked at everything PO605 is pcm failure can't run any more diagonistics till this is fixed! do i just need to replace the pcm and be done with or what?
604 is a normal code when ever you clear the codes or unhook the batterys... It is Keep Alive Memory... KAM... Nothing wrong with your computer... at least not from that code.
