Erratic idle on 1989 f-350 / 351W - Ford Truck Enthusiasts Forums
Old 01-02-2007, 03:47 PM
fireranger40 fireranger40 is offline
fireranger40 is starting off with a positive reputation.
My 1989 dually has an erratic idle problem. I took apart the TBI unit along with the poweraid block. Cleaned them both with fuel injector cleaner and put back together. If I tap the accelerator it idles high until I "tap" The spring lever on the TBI unit itself and then the idle goes down to normal. I have tried using wd40 but the problem remains. I thought butterflies just open and close and thats it? I just replaced today the TPS and is still doing the same.
Could the butterflies be wore-out? Has anybody have this problem before? What it the solution?
Thank you for your help!!!
Old 01-02-2007, 03:55 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
It sounds like the return spring is stuck and not allowing the butterflies to close all the way.
TBI is throttle body injection - something not found on Ford trucks, only on those ugly, bowtie-covered things.
Old 01-02-2007, 08:24 PM
mrl390's Avatar
mrl390 mrl390 is offline
mrl390 is starting off with a positive reputation.
Remove your IAC valve and clean it in some gasoline. That should solve your problem.
Old 01-02-2007, 10:08 PM
Thanks guys............IAC valve? Is that the other sensor located somewhat next to the TPS sensor? kinda long?
I noticed, if I tap the accelerator in an aggressive way the throttle goes back to normal until i touch the accelerator again that is.
Old 01-03-2007, 01:02 PM
andym's Avatar
Yes it is - but I doubt that's the problem based on your description. Did you adjust the TPS after you installed it?
GM TBI on our trucks doug70 1973 - 1979 F-100 & Larger F-Series Trucks 66 02-03-2015 07:52 PM
2001 Ranger Idle problems sledhaus Ranger & B-Series 24 01-16-2007 07:53 AM
TBI problem on 1989 350/351 Windsor fireranger40 1999 to 2016 Super Duty 1 01-02-2007 07:42 PM
carb. to TBI scott9320 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 7 12-04-2001 01:31 PM
Wild Idea about transplanting carb with TBI Whiskers 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 02-11-2001 08:03 PM
Tags
1987, 1989, 1996, 2001, 350, 351w, erratic, f150, f350, ford, idle, idling, prolem, tps, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
