Coil Pack Noise Capacitor
You can't always get a reliable reading from a capacitor when you check it. The best way to check it is to see if you get any static on the radio from an AM station with the engine running and if the static goes higher in sound when the engine rpm goes up. The capacitor is usually located close to the coil pack and possibly mounted to the coil pack support with a small screw. If you think it's bad you should be able to get one from a local parts store. They're only a couple of bucks or so.
sgauvry
08-22-2022 07:11 AM
alh2411
11-20-2012 11:05 AM
alvald83
06-17-2010 03:52 PM
