Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > New Jersey Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
New Jersey Chapter Join Chapter Leader: sddesigns
  #1 (permalink)
Old 01-02-2007, 11:51 AM
mrfox0246 mrfox0246 is offline
1954 Ford F-100
mrfox0246 is starting off with a positive reputation.
Stalled project - how to restart?
Greeetings from northwest NJ! Happy & safe new year! I've had a '54 F100 for about 10 yrs. Initial work in first year included getting the cab solid again (new patch panels) installing disk brakes up front, installing a 70 something Ford 9" rear, lowering all 4 corners (reversed eyes, teflon inserts, leaf removal, etc.), bought a wiring kit from Mid-Fifties but haven't completed it (should have inv3ested in a Painless kit). Lots of phases started, but need someone who'se done this to suggest what to do next; in what order. Have a bone stock 350/350 motor, no interior, no radiator. Should I paint the truck now, or wait, etc. etc.
Thanks for any suggestions
Rich
  #2 (permalink)
Old 01-02-2007, 04:05 PM
F100Central F100Central is offline
Garage is empty, add now
F100Central is starting off with a positive reputation.
You need a chearleader to get going again!
You'll have to plan the truck out because only you know the details that you're going to put into the truck. Finishing the big things let you move onto a lot of little things.
I would break it down into smaller jobs:
  1. Body Cab, doors and front end - If you can do all of the body parts at once go for it. I did the front end and then the back because I didn't have much room. The cab only goes in one place basically, so the bed will fit regardless. Put the body back on the frame and make sure everything fits up. If it doesn't fit, it's easier to fit the body without paint on the truck. Finish the body work.
  2. While the truck is together, plan out the truck. If you want to use an under dash mount master cylinder, mount it now. Mount the engine or make sure the engine clears the firewall. Do things like this.
  3. Take the body back apart and do final paint prep. Get it painted.
  4. Now is a good time to finish anything that is on the frame/under the body. It's easier now with no body on. Paint anything you need to underneath. Make sure you have brake lines run, park brake, fuel line, etc.
  5. Order the parts you'll need to mount the cab and install the front end: rubber pieces, fender welting, cowl lacing etc.
  6. Start organizing all the parts, bolts etc. for the front end and cab.
  7. Once the parts are back from paint, mount the cab. I leave the front end with just enough bolts to hold it in place. You'll probably be adjusting them anyway later. I like to put the doors on later so I don't have to walk out around them a million times while I'm doing stuff inside the cab. The hood sits kind of low so I try to do as much as I can before that goes on (wiring and stuff like that).
  8. Start wiring things up. Start under the dash and move out from there: Headlights, park lights, interior stuff like gauges, door switches and dome light etc.
  9. Install rubber bumpers, grommets etc., etc. You can do glass now or later.
  10. I don't know where that leaves us, but you should be able to go from there and finish up details.
  11. Last, attack the bed in similar fashion.
There are a ton of things I didn't type, but this will get you going. Remember to order parts in time so you can keep building. Don't let anything stand in your way...Good luck
Tags
1959, 1960, 1977, cowl, f100, ford, instal, lacing, parked, restarting, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
