Old-school bias snow tires... - Ford Truck Enthusiasts Forums
Old 01-02-2007, 10:50 AM
brider brider is offline
brider is starting off with a positive reputation.
I've been wondering if I should look for a set of the old-school bias-ply mud/snow tires for my '59 F100 4x4, or just slap on a set of modern radials.
For one, I can't find anybody on-line who sells the old type tires,
2. I wonder if they are priced way above what a modern radial would be?
Just thinking it would be nice to keep it vintage, as I WON'T be doing any long-distance highway driving (maybe 5-10 miles at a stretch, max).
Also, does anybody know what the stock size/type tire is for a '59 F100 4x4?
Thanks!
Old 01-02-2007, 11:18 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Moved to proper year forum. -John
Old 01-02-2007, 11:27 AM
texan2004's Avatar
texan2004 texan2004 is offline
texan2004 is gaining momentum as a positive member of FTE.
You might try Coker tires. They seem to be the place to go for vintage tires. Honestly though, I'd probably be more inclined to go with the radials. They are better tires and readily available.
Old 01-02-2007, 11:41 AM
irondragon79's Avatar
irondragon79 irondragon79 is offline
irondragon79 is gaining momentum as a positive member of FTE.
I've been looking around a bit trying to find a set of the older "knobby" tires to put on my F-3 when I get it done. The best I've found so far are the military NDT (non directional treads) bias plys. They aren't super cheap, but they will give me the look I want. There are a few differant places that have them, Coker included.
Old 01-02-2007, 01:43 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
Doesn't it sort of depend on what size you're looking for? Have you tried Lucas Tire, Universal Tire, Denman, and Cooper on-line in addition to Coker? In my search for 7.50x17s I found local shops (Neal Tire and Midtown here in Springfield) that could get them in a traditional looking snow tread in bias ply. And if I'm not mistaken, they're US made.
Old 01-02-2007, 02:18 PM
Col Flashman's Avatar
Col Flashman Col Flashman is offline
Col Flashman has a very good reputation on FTE.Col Flashman has a very good reputation on FTE.Col Flashman has a very good reputation on FTE.
I've used CARLISLE SURE TRAIL, PAC * STAR 902, REMINGTON's, 8 ply bias-ply 7.00x15LT tires & they sell for $65 each @ the local Tire Shop.
These of course are just Regular LT tires, but I've seen bias-ply Snow Tires in my Local Tire Shops catalog.
Just go to your Local Independent Tire Shop, NOT one of the Chain Tire Stores, & have them look through the catalog for what you need, as they are still available.
The Indy Tire Dealer will, in general, get the Type & Style of Tire for you that you request & not attempt to Bully you into something you do not wish to purchase.
Coker is to Bloody expensive for what you get, @ about $200.00 a pop per tire.
Old 01-02-2007, 02:29 PM
Quote:
The problem w/ Radials are, one cannot find or get the Style of Tread he's looking for.
Old 01-02-2007, 05:08 PM
uc4me uc4me is offline
uc4me is starting off with a positive reputation.
You might want to see if you can find some firestone town & country snows they have that old school tread pattern and are radials, although I am not sure if they still produce them
Old 01-02-2007, 06:27 PM
rhopper's Avatar
rhopper rhopper is offline
rhopper has a good reputation on FTE.rhopper has a good reputation on FTE.
If it was my truck, and I wasn't overly concerned with originality, I'd go with a radial snow. P235/75r15 became the default 1/2 pick up size some time ago (after L78-15 etc) and will be readily available at any tire store. I checked to see if Cooper still makes the Courser Traction, and they do in 700-15 and 750-16, but they're limitied production now and very expensiive.
Old 01-02-2007, 07:00 PM
52'F-3's Avatar
52'F-3 52'F-3 is offline
52'F-3 is gaining momentum as a positive member of FTE.
i've been looking for set of vintage/classic looking radial "mud tires" myself.
i want some taller skinny ones about 32", and radial ride so much better than bias ply....
I do have an older set of bias ply mud tires in OK shape i'm going to put on my F3 for now.
and i've ordered a set of these Port-A-Walls (3")..........
Hey, they only cost $50........ if they look too bad i can alway take off....
Old 01-02-2007, 07:12 PM
F6Guy F6Guy is offline
F6Guy is starting off with a positive reputation.
I am assumeing that you are refering to whats called a cross bar tread design. I have a book here that shows some vintage 4X4 trucks when new with these tires on them. They are very easy to find at any ag co-op down here.
Old 01-02-2007, 09:29 PM
48ATOY's Avatar
48ATOY 48ATOY is offline
48ATOY is starting off with a positive reputation.
I found older tire styles at Miller tire on the internet
I bought old type bias for the front of my 48 16in for a good price
look at there site or get a catalog
at MILLERTIRE.COM
Joe
Old 01-03-2007, 06:25 AM
Thanks for all the help, guys. I kind of figured a set like I want might cost more than a comparable set of radials, but I'll take a look at some of the sources you guys listed and see.
Old 01-03-2007, 03:35 PM
down here you can get a them for around 70-100 dollers per tire.
16" wheels on 3/4 ton: what size tires? GoldCo 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 01-29-2017 06:12 PM
Radials on wheels meant for 60's bias tires. 6t6merc 1961 - 1966 F-100 & Larger F-Series Trucks 16 01-25-2017 03:07 PM
Radial Tires or Bias Tires t_b0ne 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 06-01-2015 10:15 PM
Bias Ply 16.5 tires vs. Radial 16 tires... casual observations. farmallmta 1967 - 1972 F-100 & Larger F-Series Trucks 2 03-29-2015 04:16 PM
replacing bias ply tires with radials? 51merc 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 06-07-2010 06:29 PM
Tags
10, 70015, 75016, bias, cooper, courser, escape, ford, mud, mudsnow, ply, snow, tire, tires, vintage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
