axuillary or brownie transmission - Ford Truck Enthusiasts Forums
Old 01-02-2007, 11:35 AM
59flatbedford 59flatbedford is offline
59flatbedford is starting off with a positive reputation.
hello all. im looking for either a two or three speed axuillary transmission for my 64 f250. what im looking for is what models of axuillary should i look for and where should i look for them. i want something so i can keep my low rear gears for towing and pushing snow but be able to run 55 comfertably. any help would be appreciated.
Old 01-02-2007, 11:50 AM
arctic y block's Avatar
arctic y block arctic y block is offline
arctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputationarctic y block has a superb reputation
There are several over drives available. The one I am thinking of putting in my 66 F350 bolts between the bell and trans. Can't remember what it's called. I will google it if my ship ever goes by. I don't have to swim out to it as I got lots a boats.
Old 01-02-2007, 03:12 PM
are there any axullarys that came in say around one ton truck. i need something relativly small so i can put it in my f250.
Old 01-02-2007, 04:31 PM
The one I am talking about is only aroung 3 inches thick. Do a Googel search on somthinge like F350 overdrive. It fits between the trans and bell or the bell and engine as there is several styles and makes.
Old 01-02-2007, 06:46 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
GearVendors and US Gear both sell add-on units that go behind the trans. Arctic, are you thinking of the Mitchell? They went belly-up from what I heard.
Old 01-02-2007, 07:06 PM
are there any body out there that knows of some older units i could find in salvage yards or something as i don't want to spend two grand on one.
Old 01-02-2007, 07:13 PM
Quote:
Ya that sounds about right. seems I remember they were having some problems . But that was a long time ago.
converting the 86 f250 transmission 86f250-rs Clutch, Transmission, Differential, Axle & Transfer Case 1 01-30-2016 06:43 AM
Manual Transmission for my 69 F100? Anthony Pryor 1967 - 1972 F-100 & Larger F-Series Trucks 8 12-30-2014 02:37 PM
91 Transmission ID trukerdanz 1987 - 1996 F150 & Larger F-Series Trucks 1 01-11-2014 06:34 PM
Auto transmission 75hiboybeast 1973 - 1979 F-100 & Larger F-Series Trucks 6 08-24-2013 10:57 PM
Transmission Problems? Munch 1997 - 2003 F150 11 04-15-2007 12:09 AM
Tags
at529, block, bownie, box, brownie, browny, ford, gear, rebuilding, trans, transmission, transmissions, transmition, truck, vendors
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
