50 f1 hood support question??
I started to clean up and ready the hood on my 50 f1 for primer etc. I welded up the torn out holes for the latch bracket mechanism and straightened up some sheet metal and it appears to me that at one time there was a support bracket just back of the latch mechanism that might go all the way accross from the left to the right side of the hood on the bottom side. Maybe someone can confirm this and if so describe it. Thanks Ed ke6bnl
Ed- Yes there is supposed to be a support or piece of sheetmetal from side to side on the hoods. The top of it conforms to the shape of the top of the hood. The bottom edge has a notch in it with a lip bend at 90 degrees towards the back of the hood. There is a bracket spot welded to the top of the hood that it bolts to.It is held to the side of the hood with 2 flat head screws. it also has a rubber seal stapled to the top edge. There are 2 sets of holes in the hood and upper bracket depending on if you have a 6 or a 8 cyl. They do show it in the parts books. I have several extra ones if you need one.
>to be a support or
>to the shape of the
>in it with a lip
>2 flat head screws.
>if you have a 6
>or a 8 cyl. They
>do show it in the
>one.
I am intrested in adding this part, since I believe it is need for added strength what will you let it go for?
Ed ke6bnl@juno.com
>to be a support or
>to the shape of the
>in it with a lip
>2 flat head screws.
>if you have a 6
>or a 8 cyl. They
>do show it in the
>one.
Ed ke6bnl@juno.com
