'54 Radiator and Seat questions
Hey Guys - Many years reading, first time posting. Two questions: I have a '54 in different stages of finishing. I installed a '70 something Chevy 350/350 (sorry, it was a great deal) and am looking for info on what make/year radiators to use that will work. 2nd question - looking for info on what make/year bench seat will fit inside. When I can figure out how to post pics I'll post mine, in the meantime, thanks for any suggestions.
It depends on what you want to do? If you want more of the original brass radiator look or going with a crossflow aluminum type. I'm using a radiator out of a 60 F100 which actually looks similar to the originals. I got a good deal on a rebuilt one so I took it. If your good at fabrication, several people choose to go with the side flow aluminum out of the later model vehicles which cool better than the older type radiators. You need to find one that has the inlet and outlet on the correct sides of the tanks so you can install the upper and lower hose without doing majority reconstruction to your radiator tanks.
As far as a bench seat, I went with the original for ease of installation. Randy gave you two excellent examples of what works, however once again, you will have to do some type of fabrication to make any of the other seats work.
pineconeford
04-06-2014 08:20 AM
Q in Sac
19
08-22-2009 09:19 PM
scottolan
02-19-2006 08:07 PM
