BED EXCHANGES
BED EXCHANGES
Sorry I think I posted that with the y-block discussion group. Basically I was trying to find out about block/oil pump/head modifications to improve the oiling system. If you run the oil available today versus the oil of the 50's shouldn't that cure the gunk problem? If you add a pcv valve to the valley will that not pull enough air to keep the road draft tube from spitting oil? Of course I'm speaking of a motor that doesn't have blow by problems. What other tricks i.e. champhering oil holes, drilling out passage ways, restricting flow to some areas, etc.... can you do. Are some blocks superior to others in regards to oiling? my current plans call for a turned down 312 crank and that will let me run a vinyl seal to control oil loss there. any ideas?
MANY THANKS (Kenny I was shouting there)
Charles
Charles
BED EXCHANGES
Charles, I didn't see your post in the Y-block forum either. You might get a better answer if you post it there. I'm afraid I can't help you much on this question. I know oil these days is better than in the 50's and it does help, but to what degree I'm not sure. Gaskets were improved over the years also. I don't know of any tricks, but I imagine somebody in the Y-block forum would. Sorry I couldn't be of more help to you.
Kenny
Kenny
BED EXCHANGES
No need for apologies. I have learned a ton. I left a message with Mummert to see about the cost of head work. I'm a little, no a lot worried that I can't afford it. I have the equipment to port heads but I'm scared of breaking through the water jacket. I know the blocks had extra meat in them I wonder if the heads do to. I just ordered the Y-Block magazine. when I get it I will try to get the back issues dealing with porting. What do you know about porting?
thanks
Charles
thanks
Charles
BED EXCHANGES
I think I have a idea. I will be using a automatic which means the clutch slave cylinder, linkage, and hydraulic lines will be out of the way. also I will be using a floor shift so the shifter linkage including the column mounted part can be removed. Now it still dumps right on top of the steering column, however if you raise the motor and transmission about 1" (there is room to do this) things start to look better. it is still pointed at the steering column and all I have to do is reach down there and gently twist the cast iron manifold over towards the motor. crazy you say yeah so I think maybe a angled plate between the head and the manifold is in order. very crazy you say. yeah your probably right but I think I'm going to study it a little unless I find those rams horn manifolds on Saturday.
SERIOUSLY is there a possibility that this might work. It looks like I'l only need about 15 degrees.
thanks
Charles
thanks
Charles
