I may be wrong, but i dont htink that the new 5.4 is going to be in the 3/4 ton right away. They are going in the 1/2 ton first, then the 3/4 ton following
>Is the new 5.4 going to be put in the 3/4ton models?
5.4 what is that about a 335cid. Why can't Ford build something with a little more tork. What is wrong with the old FE engines More bore and stroke equals to more power. You tell me.
The 5.4 makes class leading base motor torque. If you actually work your truck you buy a diesel. That is why 2 out of every 3 heavy duty pickups are Diesles.
