460 MODS - Best Bang for Buck - Ford Truck Enthusiasts Forums
Old 12-31-2006, 11:41 PM
E30tdf E30tdf is offline
E30tdf is starting off with a positive reputation.
Question 460 MODS - Best Bang for Buck
I'd like to hear what one can do (after market external bolt ons) to a carbureted 460 for performance that gets the most bang for $$ spent. (Examples: Intake, Exhaust, etc.) ??
Old 01-01-2007, 12:10 AM
Franken-Truck's Avatar
Franken-Truck Franken-Truck is offline
Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.
Define "Best bang for the buck"
Technically I would think the most power for money spent would be a super charger, which is bolt on
But if your talking about "low" cost. . .I'd say headers/exhuast, then a straight up timing set, then recurved distributor, then grinding the smog bumps out of the exhuast ports, THEN intake/carb
Old 01-01-2007, 12:19 AM
Thumbs up Good Tips - Thanks
I have done 2 of those:
1) No smog pumps (used a set of 83-84 headers without the air holes)
2) Straight up timing gear is in.
SO I guess a bigger single and less restrictive muffler or dual exhaust might help it breath a little better, eh.
Any recommendations on intakes? I have a 600 cfm holley 4150 on the stock intake.
Is there a site anywhere giving porting instructions for the exhaust ports?
Old 01-01-2007, 12:40 AM
Anything to help it exhale to a point is good. You can over do your exhuast though, I'm no expert so I'm not going to rattle off any diameters for you. Maybe a search can guide you there or a more knowledgeable member will jump in here. Same goes for the carb/intake. I'm still learning as well, and I don't want to over carb your motor If your operating in the stock RPM range though, money spent on the intake/carb might be better spent else where. I don't think these motors ever had a problem getting air in until you start messing with cam duration and porting heads.
Wish I coulda been more of a help
EDIT: Check this site out http://diyporting.com/
Old 01-01-2007, 01:02 AM
T.R.Bauer T.R.Bauer is offline
T.R.Bauer is starting off with a positive reputation.
The best bang for the buck is NO2....sometimes it literally goes bang.
Old 01-01-2007, 01:58 AM
Superdave Superdave is offline
Superdave is starting off with a positive reputation.
Here is a link to look at some exhaust recommendations.
http://performanceunlimited.com/docu...austguide.html
Old 01-01-2007, 09:50 AM
wizzard351's Avatar
wizzard351 wizzard351 is offline
wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.
ive got weiand stealth and a 750 holley with a nitruos express 200hp plate on a stock botom end and havent had any trouble out of it yet it on my 71. before i spooled the rearend it would dangnear do an endless one wheel peel.every thing cost me less than a grand to do.if you actualy cared about blowin the engine(i dont have spares) i wouldnt run over a 150hp shot tho
Old 01-02-2007, 01:24 PM
Like I said...just go for the laughing gas. It is cheap and fun and by far the most "bang" for the buck. Besides that, you can pretend you're a dentist
Old 01-02-2007, 06:37 PM
stngh8r stngh8r is offline
stngh8r is starting off with a positive reputation.
Smile Bolt ons
->N20 always helps!
->It seems that the consensus around the FTE forum is that headers help alot. Finish off the headers with a nice 4" diesel catback(nice mandrel bends are nice too) or custom 3" true duals with some high flow straight trough mufflers.
->Carb spacer maybe? Its cheap too.
->Under drive pulley? I dont know if anyone even makes one, just shooting from the hip here.
->construct some sort of cold air system to reduce the intake air temperatures, and run a 180* thermostat.
->good ingition and fine tuning can go along ways
Old 01-24-2007, 05:03 AM
Thanks for all the tips! Maybe the post will help others as well.
Old 01-25-2007, 11:34 AM
1969fordguy 1969fordguy is offline
1969fordguy is starting off with a positive reputation.
What year engine? What vehicle is it in?
Depending on what you have I would upgrade the intake to an aluminum dual plane manifold. Maybe a Weiand Stealth or Edelbock Performer. Headers would be the #2 upgrade. After these two perhaps some nitrous.
Used parts can save you money too, sometimes good stuff shows up in the classified ads in this site.
Old 01-25-2007, 11:29 PM
79f150toy's Avatar
79f150toy 79f150toy is offline
79f150toy is gaining momentum as a positive member of FTE.
you can get an underdrive from ebay... they have them avail every once in a while (v-belt-single or dual sheave). a better distributor can help (HEI), plus higher compression (9-10:1) will make it run alot better. of course, headers and intake will always help. then, spend a little bit of time getting it all tuned in, you'll be surprised. nitrous is a good , affordable alternative, but you have to consider your comp. ratio, timing, spark plug temp, and engine temp (you could could modify these to get impressive results w/o the nitro). but funny gas is a blast.
Old 01-26-2007, 10:20 AM
wizzard351's Avatar
yeah it is fun the only thing i dont like about it is the 30 mile ride and the 50bucks it cost to refill the 20lb bottle.be for i installed a spool in the rearend a 1/4 mile one wheel peal was very possible.now with good tire and spool about a block long
July big bang BS fordpride Louisiana Chapter 166 07-31-2012 11:30 AM
89 f-250 460 cylinder 8 missfire Chucky Babe 1987 - 1996 F150 & Larger F-Series Trucks 15 12-02-2011 08:00 PM
motor choice lafermedavid 1973 - 1979 F-100 & Larger F-Series Trucks 13 10-13-2011 06:45 AM
460 headers mean green2 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 10 11-14-2010 11:08 AM
Best 460 upgrade?? grantx5 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 04-11-2005 03:56 PM
Tags
1990, 460, 4x4, bang, bb, bolt, buck, distributor, ford, hacks, modifications, mods, ons, performance, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
