Best Cold-Air Intake Brand for 6.0? - Page 2 - Ford Truck Enthusiasts Forums
Old 01-03-2007, 12:23 PM
tipdog7 tipdog7 is offline
tipdog7 is starting off with a positive reputation.
Just installed an Airaid over the Christmas break, haven't had a chance to check if it improved performance.
Old 01-03-2007, 03:41 PM
SpartanDieselTech's Avatar
SpartanDieselTech SpartanDieselTech is offline
Former Vendor
SpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to all
Quote:
Originally Posted by Mark at DPPI
03POWERSTROKER,
Here's what you get with a AFE Stage II MEGA in PG7. Quicker spool up, lower EGT's, some HP and TQ. Potential MPG increase when combined with exhaust too! For those that say the stock intake is good enough explain this away for me. When I changed my 1st stock filter element at 8000 miles (not the 30,000 miles Ford/Donaldson tell you it's good for) I got 2-3 PSI boost increase. When I changed that one at 6000 miles to an AFE Stage I (all they built at the time) I got an extra 1-2 PSI boost pressure. Plus my EGT's dropped, and because I got PG7 I have no dirt getting by. So now I have 90,000 miles and have not bought a filter since 14,000 miles, ones that cost 45-55.00 each I might add so I am saving costs and providing more clean air and get a nice rush sound when you hammer on it as a bonus. How can I get that increase in boost PSI if the stock filters last so long and flow so well. The stock filter is designed for the stock HP of the truck at best just like the OEM's have always done. The fact that you can make 400+ HP with it doesn't mean it's a "best" part to have it just means it worked around the lower flow and still made good HP.
Mark @ DPPI
Mark @ DPPI
I have personally checked the intake vacuum on that truck, before we dynoed, to make SURE we were getting all available horsepower out of it. There was none, even at that power output level.
I'm a sponsor and have an equal financially vested interest in selling products as much as any of the rest; and granted we carry aftermarket filters too. With that said, I will make my opinion as direct and forthcoming as possible-
Aftermarket filters for the 6.0 are a waste of time, money, and excess dirt. At no power output levels that 99.5% of the general public will ever see are they needed, warranted, or will do any good whatsoever. We have dynoed plenty of trucks and see NO feasible gain on mild to moderately modified trucks, and in my personal experience I have never gotten a mileage increase from one. Simple matter of fact is that not ONE single aftermarket filter that lives up to the filtering efficiency of the Donaldson. The AFE is efficient; the Donaldson is more efficient.
Spend your money and time elsewhere.
Old 01-03-2007, 04:38 PM
Bob Ayers Bob Ayers is offline
Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.
Excellent post Matt!!!!! We need more information like this to keep youngsters from throwing their money away on useless performance mods!!!
Old 01-03-2007, 04:40 PM
Customz's Avatar
Customz Customz is offline
Customz has a good reputation on FTE.Customz has a good reputation on FTE.Customz has a good reputation on FTE.
Quote of the day:
Quote:
Originally Posted by Mark at DPPI:
'and because I got PG7 I have no dirt getting by'
Old 01-05-2007, 03:28 PM
blackhat620's Avatar
blackhat620 blackhat620 is offline
blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.
Matt,
Another great post as usual.
Old 01-07-2007, 08:18 PM
Mark at DPPI Mark at DPPI is offline
Mark at DPPI is starting off with a positive reputation.
PSD 60L Fx4,
Ok if the test showed no gains can you explain to me how I got 2-3 extra PSI of boost pressure when I replaced the 1st stock Donaldson at 8000 miles to see what would happen with a new Donaldson. And then at 6000 miles on the second Donaldson I replaced it with the AFE Stage I and got 1-2 more PSI again.
Mark @ DPPI
Old 01-07-2007, 10:40 PM
Former Vendor
PSD 60L Fx4,
Mark @ DPPI
Without knowing the conditions your Donaldsons were seeing, I most certainly cannot explain. For all we know, they were under dust and dirt conditions that most filters do not see. Simple matter of fact is that the Donaldson has more dirt holding capacity than any of the aftermarket filters- if you don't believe me, search this forum for more of these discussions- you will see links to solid independant testing, from people who have no vested interest in selling the product.
As far as the boost gain from the AFE, keep in mind that AFE relocates the Mass Air Flow sensor in the new tube. It is a well known fact that in the first stage two kits this sensor was located wrong and caused issues, to the point of setting the check engine light on some vehicles.
A Mass Air Flow sensor is calibrated to the diameter of the tube of which it is mounted (and likewise the position of the sensor mounting) and increasing the diameter of this tube like AFE does destroys the calibration of the sensor. Given that the tube is bigger, the velocity of the air at a given airflow is less, and the sensor would correspondingly read that there is less airflow than there actually is. The 6.0 uses this reading to determine a calculated Air/Fuel ratio; and correspondingly sets the duty cycle of the turbocharger to match the fuel delivery to obtain the correct calculated A/F. If it thinks it has less than the desired quantity of air, it will increase the turbocharger duty cycle to make up for it- which an increase in duty cycle will always result in an increase in manifold pressure.
This gain in boost pressure is NOT from "filter efficiency" as AFE and others like to claim, but because the truck is out of calibration and commands the boost increase. Until you can provide me with a datalog showing the boost increase at the same VGT duty cycle, I'll be sticking with my original statement.
Old 01-08-2007, 08:42 AM
Beachbumcook's Avatar
Beachbumcook Beachbumcook is offline
Got Diesel?
Beachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to all
Matt... great post above... tried to leave some + rep points... but had to pass some around.
What a great post and explanation of why some of the "overboost" issues and why some aftermarket air intakes do not operate well or why there are "just issues" or lack of documented proof.
May need to make your post above a sticky... as it would answer many other people's questions about intakes and their questions about them????
Again... great explanation and I believe very hard for anyone to refute your analysis and understanding... but hey... I am all ears for some to give a rebutal!!!!!!
Old 01-08-2007, 04:01 PM
03f350crew 03f350crew is offline
03f350crew is starting off with a positive reputation.
Quote:
Originally Posted by 03POWERSTROKER
What is the best cold-air intake for the 6.0 diesel?
FORD!!!
Old 01-08-2007, 07:04 PM
mrxlh's Avatar
mrxlh mrxlh is offline
mrxlh has a good reputation on FTE.mrxlh has a good reputation on FTE.mrxlh has a good reputation on FTE.
Quote:
Originally Posted by 03f350crew
FORD!!!
Yep, the one that came on the truck.
Old 01-09-2007, 04:32 PM
Desert_Dude's Avatar
Desert_Dude Desert_Dude is offline
Desert_Dude is starting off with a positive reputation.
But they SOUND SOO GOOD!!!!!!!!!
Air flow suggestions In and out LuckyT 1999 to 2016 Super Duty 3 11-02-2014 01:46 PM
Need Exhaust System Recommendation... dmallen Exhaust Systems 9 07-01-2014 05:30 AM
New 2013 F-350 6.7L FWW82 1999 to 2016 Super Duty 10 06-21-2013 11:43 AM
5.4L Power Upgrades jd1083 1999 to 2016 Super Duty 6 03-03-2011 02:52 PM
1988 F150 Cold-air intake? mikemustang289 1987 - 1996 F150 & Larger F-Series Trucks 15 07-12-2007 12:57 PM
Tags
2007, 60, accufab, air, cold, diesel, elbow, for60l, ford, forums, intake, jobe, performance, power, powerstroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
