clutch rattle
clutch rattle
Hey Yall, I have a bad rattle coming from the clutch area when its idling and I heard horror stories about the fly wheels on these trucks. Can someone tell me about these fly wheels and the best way to stop this rattle. I have a 94 F-350 with a 96 7.3 5 speed
thanks, Steve
thanks, Steve
The flywheels on these trucks are two piece from the factory, with the isolator springs you usually find in the clutch disc placed instead in the flywheel. My advice would be to replace the clutch pack and flywheel with one of the aftermarket one piece conversions. You will have to do both, the factory clutch will not work on the aftermarket flywheel as neither has the springs in it and you need them one place or the other. I opted for the LUK conversion from TYMAR PERFORMANCE, there are several others available and any number of suppliers. I had my clutch replaced when I bought the truck (no place to work and no time). I had a factory setup put in at that time - I had not yet found the wealth of information on these trucks and did not know about the two piece flywheel or the conversion kits. After 100,000 miles or so I replaced again because the flywheel had failed. The clutch I took out had 70-80% friction surface left, it would not release properly which took out my transmission synchronizers so I replaced both the tranny and clutch. I could not be happier with the clutch. Pedal effort is half, engagement is not right at the floor and the new clutch is an inch larger in diameter.
Dave / Believer45
Dave / Believer45
could a DMF going bad cause hard (er than normal) shifting? Just wondering because I have no pedal play (replaced all bushings) and it still doesn't shift like I would like it to
When I replaced my clutch with the LUK single mass conversion it moved the engagement point 2-3" off the floor. My pedal box bushings have some wear and I was going to replace, but no need with the clutch conversion.
Dave / Believer45
BltFordTough
11-28-2005 10:32 PM
