4 FEET snow on roof
Anything with a long handle will do the trick. The real problem is how to do it without bringing a bunch of snow down on your head.
If the roof isn't too stteep, I'd just use a ladder to climb up there and very carefully shovel it off the centre portion of the roof. Then use a rake or soemthing to pull the rest down from below.
Take a few pictures. In a few years when you are talking about this at your x-mas gatherings, it never hurts to have evidence so you aren't called an exagerator!
Good luck!
Good luck!
If you are worried about the pile up around the base of the house when you do this.
Make sure you have a tarp stretched out on the ground first to pull the snow away when you're done..... In incruments
BTW <> sorry about dropping so much at your place..I intended it for the Illinois,Ohio,Vermont and other NE areas
Grab yer shovel and get busy. We have to do ours here two to three times a year. Like Fordzlla said, leave an inch or two. Saves on the roof and it acts like an insulator. Enjoy winter and take breaks. Good time for a heart attack. Spring is just around the corner, maybe.
Edited for my spelling errors.
http://www.denverpost.com/headlines/ci_4926609
http://photos.denverpost.com/galleri...l#id=366&num=1
Dutch will like #8
#15 is good
# 19 isssssss GREAT !
Make sure you view all 27 of them.
Dutch will like #8
#15 is good
on
To give you an idea of how much weight is up there. We filled a garbage can with snow. turned it upside down and cut a 1 cubic foot out of it. It weighed 22 pounds on a bathroom scale. Had light drizzle for a couple of hours that night and it was 57 pounds the next morning. Get a bucket and put some snow in it than weigh it. Figure the square feet of your roof and see if ya can sleep at night. It scared h*ll out of me.
