Motor Laws in the great State of MO
OK ? of the day.
Can anyone tell me where I can find the law (number of bill and stuff if possible) on the MO books that states what the limitations on motor swaps in regards to original engine size vs replacement engine size. The one thing I found at the DMV site was that it had to be like make or manufactor. That is at best vague so figured there was something somewhere that would clear it up. I am really wanting to plan a 289 or 302 swap for my ranger that is currently running a 4.0L v6.
Thanks!
Scott Tomlinson
Chillicothe, MO
93 Ranger Ext 4.0L (wanting new motor and splash bed really bad!)
99 Expedition 5.4L (super chipped, true duals, AEM cold air intake, STILL need more power!
04 Custom built chopper ( I know but it's really cool and lives with two Fords, that should count for something! he he)
Thanks!
Scott Tomlinson
Chillicothe, MO
(A) Effective July 1, 1992, all light-duty
vehicles which are passenger vehicles with a
Gross Vehicle Weight Rating (GVWR) below
six thousand pounds (6,000 lbs.) and commercial
vehicles with a GVWR below eight
thousand five hundred pounds (8,500 lbs.),
which receive a replacement engine, in
regard to all emissions related parts, engine
design parameters and engine calibrations,
must comply with the certified configuration
of the same or newer model year as the vehicle
chassis.
(B) Effective July 1, 1992, diesel powered
vehicles may receive a replacement gasoline
engine if the resulting engine-chassis configuration
is equivalent to a certified configuration
of the same model year or newer as the
chassis and that chassis has been certified
with a gasoline engine.
(C) Effective July 1, 1992, heavy-duty
GVWR in excess of six thousand pounds
(6,000 lbs.) and commercial vehicles with a
GVWR in excess of eight thousand five hundred
pounds (8,500 lbs.) may receive a
replacement heavy-duty engine if the resulting
vehicle is identical to a certified configuration
of the same model year or newer.
Under no circumstances may a heavy-duty
engine ever be installed in a light-duty vehicle.
(D) All 1968 and later model vehicles
which received a replacement engine before
July 1, 1992, must be equipped with all the
air pollution control devices installed by the
manufacturer on that particular engine.
(E) Reject vehicle if a:
1. Replacement engine is not equivalent
to the certified configuration of the enginechassis;
or
2. Heavy-duty engine is used in a lightduty
chassis.
Even more confussing info here: http://sos.mo.gov/adrules/csr/current/11csr/11c50-2.pdf
chassis.
or
chassis.
And more . . .
(6) Motor Change Vehicles.
(A) A person presenting a motor change
vehicle for a VIN verification will be
required to present the following, when applicable:
1. The vehicle with the necessary parts
removed for examination;
2. Proof of ownership for the basic vehicle;
3. Proof of ownership for the engine or
an affidavit of motor change; and
4. The Vehicle Examination Certificate
properly completed and signed.
(B) The director of revenue will determine
how the vehicle will be titled.
Originally Posted by chopper06
Does that say that I can't put a bigger motor in than is available in that model year and any year since then? OK my head hurts!
I think you're best bet is to ask someone at an inspection station since they are the ones that will make the final call. If you don't know anyone, my mechanic buddy here will tell me. He just passed his inspection renewal so I know he's up to date on the regs. I can ask him Tuesday if you want me to.
Ive got a family member with a 383 Chevy in a Ford truck.
As far as I know, you just have to be able to pass the emissions standards for the vehicle that is described on your VIN
A good majority of the employees at the emission stations wouldnt be able to tell a cummins diesel from a chainsaw motor.
I tried to do every thing legal on my swap after spending 2days on the phone with socalled head of veris departments of motor vehicles and DOT.I have had a diesel in my old ford since 93 a 372 Perkins and a 6.0 Perkins that it is in it now.each person didn,t know what to tell me ecept for one women she read me the riot act told me that I had to take that motor out now.And said that if I got pulled over the H.P. will make me take it out on the side of the road .I just told her OK. I have been around alot of H.P. they just lookat it and smile I just tell them I went from 6mpg to 25mpg.It is still regesterd as a gas.
Dale
Dale
mainly it up to the inspector...down here for a while they were heck on a s-10 w/350 and rangers w/5.0 but now it's cool and a hp usally don't ask what motor you got in there and won't ask about it or check it unless its...
loud / doing burnouts donuts racing ect.
your doing 120 in a 40 zone
or running drugs
or running drugs
So let me make sure I have this right. As long as I am not bellowing smoke, from either the exhaust or the tires, producing decibels above and beyond the normal engine sound from either the pipes or the marble grinding under the hood, running pink slips, shine, meth, pills, illegals or guns and my inspector doesn't pop the hood I should be fine in making this swap? Just in case the inspectors in my area turn out to be turds about this (North Central MO has some real nasty State inspectors, think they were either hugged to much as a child or not enough but they have issues) where would you boys recommend area wise that a fella might have a little less headache with a MVI?
Thanks for all the post, they have been……enlightening!
Chopper06
I don’t care how hot she is, she could drive a chevy!
Chopper06
