external tranny filters
are these junk?
http://cgi.ebay.com/ebaymotors/IN-LI...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/Ford-...spagenameZWDVW
Rob
http://sgtsandler.tripod.com/index.htm (no updates in a about a year)
2001 Ford F150 SuperCrew Lariat 4X4
Hypertech Power Programmer
Hypertech Powerstat 160 Thermostat (hesitatnt to install)
Custom dual rear exit pipes with Flowmaster muffler
K&N Series 77 Cold Air Intake
Cooper ATR 265/70-17
Rob
transmission wear is just thea "transmission". the junk falls to the bottom of the pan, the only way it gets out is to go thru the suction filter, then the pump, valve body---- then to the radiator and converter. dont filter it at the end, filter it before it gets into the valves. better off to clean the pan, change the filter and wipe off the magnet.
Rob
filters
At 125000 I pulled the pan, installed new 1-2 and 2-3 accumulators, high line pressure valve and a shift kit. At the same time I welded on a 1/2 pipe coupler to the bottom of the pan sump for a drain. I installed a remote spin-on filter also because I had pulled the pan at 115000 to put in a new filter and then at 125k the amount of crap in the pan was enough to convince me of the validity of an actual and easily changed filter. I would not say that the pan shouldn't be pulled to change the internal filter and clean the pan but the extra filtration has to be good for longevity. By the way, the shift kit was a fantastic modification. No more of the slushy feel.
zigzkidz
03-20-2008 07:15 PM
Bird Dog
32
07-12-2007 04:56 PM
