Tire and rim sizes for 95 Ranger
Old 12-30-2006, 09:41 AM
Turnbury95Ranger's Avatar
Turnbury95Ranger
Turnbury95Ranger is offline
For a 1995 2wd Ranger, will the following setup work without interference or offset problems:
I can pick up a set of rims from a 2005 Ranger...15 x 6" wide with a bolt pattern of 5 x 4.5. I have a set of tires to mount that are 205/70/15. The truck presently has a set of 14 inch rims on it.
Thanks in advance. Bill
Old 12-30-2006, 10:54 AM
Hank85713's Avatar
Hank85713
Hank85713 is offline
you should not have any problems. I put 265-70 15s on my 94, you will need to recalibrate your speedo when done.
Old 12-30-2006, 01:25 PM
RangerPilot's Avatar
RangerPilot
RangerPilot is offline
They'll swap right in without any problem. Since your tire size is dropping you will have to reset the speedo as Hank said. Your dealer can do it for you.
What are you doing with the old rims?
Old 12-30-2006, 04:37 PM
frankenbroncoII's Avatar
frankenbroncoII
frankenbroncoII is offline
the only issue you might encounter is the speedo being off a lil bit.
Old 12-30-2006, 06:19 PM
Turnbury95Ranger
Thank you all for the information.
Gear619
03-10-2015 01:44 PM
Padft12Laws2Liv
04-16-2012 04:13 PM
hotroddually
10-12-2009 09:56 PM
KooLaid
Colorado Chapter
11-04-2004 01:37 PM
IES
13
11-07-2002 06:14 PM
Quick Reply: Tire and rim sizes for 95 Ranger
