I am re-attaching the front frame horns on a 52 1/2 ton frame. The P.O. removed them but I want to have a bumper on mine. What is the overall length of the stock frame for a '52 1/2 ton truck?
Measuring along the bottom of the frame, from the center of the forward-most rivet on the front crossmember to the end of the frame horn (I measured the passenger side, didn't think to do both) is 13.25". The upper rail is a little longer due to the angle (it matches the curve of the bumper), but I can't measure that right now. The upper also sweeps upwards a little, in other words the rail becomes wider to match the bumper. If you need more measurements I would defer to someone who has their front end off, I can't measure the top rail accurately with it all together.
