ID Help: Holley List 7158-1 & D5TE-9510-CB - Ford Truck Enthusiasts Forums
Old 12-29-2006, 12:08 AM
rlh's Avatar
rlh rlh is offline
rlh is gaining momentum as a positive member of FTE.
I have what looks like a Holley 4160 that came with an 86 Bronco (351W ) that I bought a couple of years ago and am trying to ID it better. It apparently came off of a Ford truck in the mid to late 70s. I can't find the list number in my Holley book or web site. It has a metering block for the secondaries instead of a plate but only has a single diaphragm pump, otherwise I would suspect it to be a 4150. I am interested in determining the cfm rating and the correct kit for it.
The ford casting is: F5TE-9510-CB which just translates to 1975 and 9510 tells met its a carb, duh! I assume CB is the revision code.
The list is 7158-1 which isn't in my Holley book or the site.
Thanks
Old 12-29-2006, 08:38 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
It is off of a 75 Truck. 600cfm. The kit will found using the F5TE #.
Old 12-29-2006, 08:58 AM
rlh's Avatar
rlh rlh is offline
Thanks. What's the story on the secondary having a metering block rather than a plate?
Old 12-29-2006, 09:13 AM
LxMan1's Avatar
Some earlier versions used them, then they started using the metering plate. Cheaper I guess.
Holley list 6947 lookin for rebuild kit Buckhorn2 Fuel Injection, Carburetion & Fuel System 6 11-27-2013 02:02 PM
stock Holley 2 barrel on a 292 y block big boy toys f250 1961 - 1966 F-100 & Larger F-Series Trucks 4 01-01-2012 10:57 PM
Sick Hippy bus sploder8 Large Truck 20 12-04-2010 11:32 AM
Can anyone ID this Holley carb for me? beachrat Fuel Injection, Carburetion & Fuel System 7 03-07-2006 03:35 PM
Help ID Motorcraft carb jc78 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 05-26-2001 06:38 AM
Tags
7158, 71581, 9510, 9510cb, carb, casting, cb, d5te, d5te9510, d5te9510cb, ford, holley, kit, list, list71581, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
