What is it?
What is it?
Ok, I found a truck (or at least a body) in a junkyard. The guy that owns it says it is either a 55 or a 56. It says F-100 on the hood. However, it looks very much like a 1-ton. I though that all F-100's were 1/2 tons. SO what I want to know is this: Is this a stock truck or is this something someone made? Also, will the body fit on my F-100? Thanks ya'll.
What is it?
Go to the FTE picture gallery and you should be able to tell whether it is a '55 or '56. The simple way to tell is that a '56 has a wrap around windshield with a vertical "A" pillar.
Re: F100's, yes, they are all 1/2 ton's. However, hood emblems can be changed and hoods can be changed as well. The emblem is different between '55 and '56.
Hope this helps,
Tim in Burien
Hope this helps,
Tim in Burien
What is it?
Something about that truck just bothers me. I have a 1976 F-100, which is NOT a small truck, and this truck just straight up makes it look puny. The more I think about it, the more I think that the 56 cab on it is NOT stock. I think someone put another cab on it because it has 1 ton rims, a flatbed, and duel tires on the back. It's a bad-a$$ looking truck and if it had an engine, I would probably fix it up. But I think just swapping bodies will be a whole lot less headaches.
What is it?
If it has dual wheels it is at least a one ton. Does it have 6 lug nuts on each wheel? Are the wheel sizes 16"? I have a '55 F350, which is a one ton truck. The rear has dual wheels that are 16" in diameter. Any wheels larger than that means that it is a heavier (or larger) truck, such as a 450, 550, etc. I agree that they are cool. Mine is only a cab and chassis but I am working on it now. The 3/4 tons has single rear wheels with 8 lug nuts.
Mike
Mike
