Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-28-2006, 01:35 PM
ron dennis ron dennis is offline
Garage is empty, add now
ron dennis is starting off with a positive reputation.
Compressed Natural Gas fuel filter help please
I took my 97 f-250 5.4 liter to ford due to hard start and rough funning condition. They told me the #5 fuel injector was bad and that my fuel filter needs to be changed (they feel this clogged the injector).
When you use cng the copressors need lubrication and that contamination (at least to a cng system) needs to be removed via the fuel filter.
I went to Alldata which is at my local library but I found no information on how to change out this type of cartridge filter. I only found a way to bleed off the pressure under the hood which has already been decreased from 3000 psi to a much lower pressure of around 100 psi + or -
Does anyone know how to cut off the pressure on the 3000 psi/ inlet side of the fuel filter....even ford had no exploded view of the filter housing.
Any help would be appreciated, thanks ahead of time.
Ron
  #2 (permalink)
Old 12-28-2006, 03:23 PM
Randy B Randy B is offline
Randy B is starting off with a positive reputation.
Ron
I believe you are in the wrong forum. This is for 2007 Expeditions.
Randy B
  #3 (permalink)
Old 12-28-2006, 09:16 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Welcome to the forum Ron
I've moved your question to a more appropriate place for you.
I assume you have a factory CNG conversion?
These don't use a serviceable filter. They use a coalescer/filter assembly that has a drain plug on the bottom. It's on the frame rail roughly under the driver's seat.
The CNG fuel system shouldn't have caused a plugged injector. The CNG doesn't actually go through the fuel injector. The CNG enters the engine through a sleeve that's around the injector.
Most likely it was plugged due to not being used because the truck is run mainly on CNG. Most of the CNG or LPG trucks I've seen with bad injectors just needed an injector flush. It probably would be a good idea to replace the gasoline filter too.
__________________
Dave - FTE moderator
Forum Guidelines
this space for rent
  #4 (permalink)
Old 08-16-2007, 10:56 AM
tszukala tszukala is offline
tszukala is starting off with a positive reputation.
coalescer o-ring
Is the o-ring on the drain plug for the coalescer made of a special material? Should it be purchased from Ford or will any 0-ring of the correct size work? I don't know the properties of propane and if it's corrosive to certain 0-rings.
  #5 (permalink)
Old 08-16-2007, 03:51 PM
gasman6674's Avatar
gasman6674 gasman6674 is offline
1996 Ford F-350
gasman6674 is starting off with a positive reputation.
The O-ring Should be Buna-N.
__________________
Jim England
Do you have Gas? Propane Execeptional Energy
2012 Escape Ltd FWD, 2005 Explorer Sport Trac 2WD
2004 Escape Ltd FWD, 1996 F350 7.3L CCLB DRW,3" DP,4" Exhaust, Cat Delete, 6637
2012 V-Cross V27FK Super Lite by Forest River TT
  #6 (permalink)
Old 05-30-2008, 01:02 AM
vaughnr007 vaughnr007 is offline
vaughnr007 is starting off with a positive reputation.
Jim England
Do you know where we can find replacement Coalesant filters for the Ford PUs? I hate to buy them from the Ford dealer!
RV
  #7 (permalink)
Old 05-30-2008, 09:33 AM
It took me a while to track down the distributor in the US but I finally did and they provided me with filters for $65 + shipping versus $490 from a Ford dealer.
The distributor is:
BAF Technologies
2415 Beatrice St.
Dallas, Texas 75208
214-231-1450
I have a 2001 F-150 5.4L stock Propane bi-fuel and the part # is A3-514 (GFI LPG Fuel Filter)
  #8 (permalink)
Old 03-13-2010, 10:08 AM
jackpatel67 jackpatel67 is offline
jackpatel67 is starting off with a positive reputation.
I have a Ford 250 CNG dedicated and i took it to the ford dealer to change the feul filter. They told me I have oil in the feul filter and the tank. They said i have to flush the tank and change the injector and feul filter. What should i do??
Tags
150, 54, a3514, cng, f150, f250, filter, filters, ford, fourm, fuel, gas, natural, propane, replacement, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
