1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Oxygen sensor replacement
Old 12-28-2006, 12:54 PM
jokerswild130's Avatar
jokerswild130
jokerswild130 is offline
Question Oxygen sensor replacement
I was told the fuel system on bank #1 was too lean, and that I should replace my O2 sensor. How do I replace the sensor?
Old 01-01-2007, 10:36 AM
ubereal2's Avatar
ubereal2
ubereal2 is offline
Wink O2 sensor
Lean or rich fuel mixture could easily be you're oxygen sensor. Not a hard task, it will have a single plug to undo and you can buy a socket to remove the sensor, or a 7/8 wrench should do the trick.
Bob
Old 01-03-2007, 09:13 PM
WALTDOGG77's Avatar
WALTDOGG77
WALTDOGG77 is offline
There are 4 O2 sensors and 4 cats for our trucks. The one near the the starter is the hardest of them all to get. If you have a lift it will make the job alot easier. You can get the sensors from Auto Zone at $50 per. All senors are made by bosch, even the ones at the dealership.
Old 01-03-2007, 10:38 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
"Lean" codes are seldom due to faulty sensors.
Post your EXACT fault codes for informed suggestions.
Steve
Old 01-04-2007, 06:04 AM
ubereal2's Avatar
ubereal2
ubereal2 is offline
Red face Up or Down?
Have you had the truck scanned? Some part stores will scan for you free. That should show a upstream or downstream sensor.
Upstream is by the exhaust manifold. Downstream is closest to the converter.
Bob
Old 10-02-2007, 10:02 AM
Bostonsound's Avatar
Bostonsound
Bostonsound is offline
I had the same issue and I could not for the life of me get the tool ( Socket ) onto the Sensor by the starter. After about an hour of fussing I gave up for the day. Do you have to remove the starter to get to this sensor?
Old 10-19-2008, 09:29 PM
jc-well's Avatar
jc-well
jc-well is offline
O2 sensor replacement
I changed all four of my O2 sensors today and I understand what you are going through. I changed the other three sensors in about 10 minutes all together. However, the one you are speaking off took some time. I didn't have to remove my starter. I cut the wire on the old one with a pair of wire cutters. Took the sensor out with an open end wrench. Used a long skinny flat tip to to press the connector tab and pulled on the wire that I had cut to remove the connector end. It did take a lot of patience.
Old 10-20-2008, 07:24 AM
Johnny Langton's Avatar
Johnny Langton
Johnny Langton is offline
No,not all sensors are made by Bosch,and definitely not all OEM sensors are Bosch. Some applications are,but the large majority of OEM Ford sensors are NTK,and with good reason.
JL
Cell's
04-03-2022 10:56 PM
gccch
2004 - 2008 F150
08-25-2014 12:50 PM
CarbonClear
06-09-2011 11:33 AM
tommybrede
04-07-2010 09:28 PM
Steve A
07-08-1999 11:27 PM
Quick Reply: Oxygen sensor replacement
