overdrive light
Old 12-27-2006, 08:23 PM
jc2's Avatar
jc2
jc2 is offline
overdrive light
i have a 1996 f 350 7.3 powerstroke automatic with overdrive . when i got in truck today and started up the overdrive light is now blinking and when i drive truck the transmission is shifting very hard, it will jerk you in the seat.but its not slipping and overdrive works when i turn on and off, but the hard shifting concerns me it didn't start this until overdrive light started blinking. any ideas
Old 12-27-2006, 10:56 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Have your codes read. You will need a scan tool that supports manufacturer-specific codes, a feature seldom found in el-cheapo scanners.
The computer has detected a fault with the transmission and has put it into "fail-safe" mode. One of the key attributes of this mode is a greatly increased EPC pressure that will really slam the shifts.
If you're lucky, it might just be an easy to replace sensor. Once you have the code, a proper diagnosis can (and should) be made before purchasing any parts for replacement.
Steve
Old 12-28-2006, 06:01 AM
jc2's Avatar
jc2
jc2 is offline
thanks steve i will get it scanned
BriR
1997-2006 Expedition & Navigator
18
04-16-2021 09:08 PM
patsalters
09-11-2013 09:43 AM
jonnyboy78023
18
03-24-2008 11:00 PM
Renegade25
06-06-2007 11:34 AM
tfrazee
1997 - 2003 F150
54
03-23-2004 06:24 PM
Quick Reply: overdrive light
