2004 F150 Tow Rating - Ford Truck Enthusiasts Forums
Old 01-09-2003, 09:36 PM
brbowers brbowers is offline
brbowers is starting off with a positive reputation.
Post 2004 F150 Tow Rating
I see the Maximum tow rating for the 2004 F150 is 9500 lbs. I imagine that is for a 2wd regular cab truck. Does anyone know what the tow rating will be for a 2004 F150 Supercrew 4x4?
Old 01-11-2003, 03:49 AM
Boss_358's Avatar
Boss_358 Boss_358 is offline
Boss_358 is starting off with a positive reputation.
I would assume that Ford would have the specs up on their website soon. I still have yet to check it out.
Old 01-11-2003, 02:06 PM
hitecdan's Avatar
hitecdan hitecdan is offline
hitecdan is starting off with a positive reputation.
You're correct. Ford advertise the max tow rating based on a "standard" truck. Standard truck usually means the lightest truck configuration in the line up. Add a crew cab and you'll loose about 300 lbs or so off the tow rating. Add 4 wheel drive and lose another 100 lbs. Don't look at the advertised number, you have to look at the GCVWR (Gross Combined Vehicle Weight Rating) then subtract the actual weight of the truck, cargo (options can be considered as cargo too) and passengers. The number you have left will be how much you truck can tow.
example:
My 93 F-150 has a GCVWR of 11,500 lbs.
11,500 lbs.
-5,300 lbs. (the weight of the vehicle with all options and wet)
___________
6,200 lbs tow capacity.
-200 lbs for driver
___________
6,000 lbs tow capacity
Adding more cargo and passenger will further decrease my tow rating because I can't safely exceed the GCVWR or 11,500 lbs.
Old 01-11-2003, 06:26 PM
mgazak's Avatar
mgazak mgazak is offline
mgazak is starting off with a positive reputation.
Percentage of max tow marcortez Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 18 12-02-2016 12:48 PM
Rated towing capacity 96 f250 diesel? automaticlee 1987 - 1996 F150 & Larger F-Series Trucks 5 10-05-2016 08:38 PM
2004 F250 CC 8' bed vs 2012 F150 Eco SC 8' bed Sean O 2009 - 2014 F150 4 09-14-2015 03:54 PM
Improving Towing Capacity - Chips, Air Filters, Headers, Superchargers? mickey mouse Fifth Wheel & Gooseneck RV Towing 7 04-16-2002 08:40 AM
F150 1998 and 2000 Tow/trailer ratings? Can take camper & boat? jdaugela Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 7 12-28-2001 03:27 PM
Tags
04, 06, 150, 2004, 2005, 2005ford, 4x4, capacity, f150, ford, gcvwr, rating, ratings, tow, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
