4.6 to a 5.4?
4.6 to 5.4 swap...
IT WILL COST you 4k esh maybe little less or MORE depending on...
how much you spend for the 5.4
is the 5.4 come with all its parts... intake/sencers.... a rebuilt isent pretty...
If you want to install a 5.4 inplace of your 4.6 you have to really want to because
most shops will not do this because they are scared and you need the tools and a
little help...
I payed 1900 for a used 5.4 with o most all its parts... 60k miles on it...
used my 4.6 air intake and MAF
used my 4.6 coils packs/wires
used my 4.6 computer
Payed to installed highflow cats with pipework for manafolds to bolt up $400
Payed for a 8bolt flywheel $40
Hoeses for fule line/Bolts/stuped stuff that broke $100-200
Plus i got new P/S pump and Water pump... not sure of prices ... forgot
Man if it wasent for my buddy who had all the tools... I would have naver got this
done by my self....
You have to use the wire harness off of the 4.6 and put it on the 5.4 and do a little
cut and wire for some sencers that are longer away then on the 4.6 and the knock
sencer has to be rewired because both the P/I 5.4 and none P/I 5.4 both to be wired
for that issue.
little help...
done by my self....
for that issue.
Originally Posted by gui88ford
i would be interested in knowing what it takes....i'd assume a new computer, maf, injectors, but maybe not.....i have a 4.6 now and i'd like to go to a 5.4 when it's that time...
The exhaust will need to be refitted due to the taller deck block,and the COP will need to be changed out to packs/wires if your truck had them. The MAF and injectors from the 4.6L will be fine,and the EEC from the 4.6L truck wil work too-you'll just need a tune for the displacement change so load calculation isn't all screwy.
JL
the only way i would try this swap is with haveing the donnor truck that the motor came from.Just to have every thing else that may be needed. which i feel many of the fte guys have already stated. Good luck guy i think when it's all done you will be pleased with the hard work you did and gains received
by no means do you need a donor truck... you can fab things up and such... it comes down to how good you can think...
Lets say you have some hose inside your house for something stuped...
The motor is missing a hoes that is not normal...
The hose in the house works...
**** Its stuped things like that, that need to be worked out...
But if you have free time... a extra hand... And you know how to pull a motor...
YOU WILL BE 100% fine... just take your time and ask questions on things that stump
you... But dont get to ask happy... Because when you do things suck... You have to
stay on your feet ...
Im sorry i might not be makeing sence im just saying what i learned out loud lol...
Originally Posted by BURNSTOUGHFORD
What about motor mounts? and your telling me the PCM and the wireing harnes from the 4.6l will work?
JL
