Question? Best way to remove exhaust flange bolts - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 12-26-2006, 07:52 PM
DHassel DHassel is offline
DHassel is starting off with a positive reputation.
Question Question? Best way to remove exhaust flange bolts
I'm installing a used engine in my '94 Ranger. What's the best way to loosen the two exhaust flange bolts? I already broke two (passanger side) after applying heat & liquid wrench & tapping. The two bolts broke off at the head. Guess now I'll have to drill them out but still have the other side to go. I'll probably just cut the ones on the dead engine as I won't be bolting anything up to them! ;-)
5.4 exhaust bolts on the cat to y flange are spinning? zimm 1999 to 2016 Super Duty 2 01-02-2015 05:17 PM
09/99 DIY up pipes welded flange w/donuts and vibrant bellow Michael Mehegan 1999 - 2003 7.3L Power Stroke Diesel 2 02-01-2014 06:37 AM
Exhaust manifold flange - flare vs. weld Bozworth 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 04-10-2012 12:43 AM
Flange from CC to muffler broke. Request replacement part numbers rob_engineer Explorer, Sport Trac, Mountaineer & Aviator 1 07-18-2011 08:29 PM
1966 ford 390 to 390 gt heads ford79man91 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 6 06-20-2011 11:33 PM
Tags
1997, 94, bolts, broken, easiest, exhaust, exsaughst, flange, ford, loosen, ranger, remove, removing, studs, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
