Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 12-26-2006, 03:34 PM
beagledog beagledog is offline
Garage is empty, add now
beagledog is starting off with a positive reputation.
diesel emissions testing in NJ?
I've just purchased a '92 F-350 w/a 7.3 and a 12' stake body dump. I live in NJ. Having a background in chemistry, pumps, pipes and valves and farming, I plan to start making and running bio in the rig. First though, I need to work my way through the registration and inspection process we have here in NJ. I've just spent over an hour on their site, and I'm still confused. Hopefully there are some other NJ Bro's/Sis's that can answer a q for me. Here goes: What emissions inspection/testing requirements do I have here in NJ? It would possibly appear that there are none provided I tag the truck for 18K or less in weight. However, diesels taged for les than 18K are not listed on the emissions testing expemtions pages. Not talking about the basic safety inspection, but the diesel testing stuff. Thanks
  #2 (permalink)
Old 12-26-2006, 08:30 PM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant future
f250juggernaut
Most states that require diesel testing do little more than a snap throttle opacity test.....so in most cases as long as it aint smokin' it will pass.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
  #3 (permalink)
Old 12-26-2006, 09:31 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
What's the GCVW your truck is rated for. I'd be willing to bet it's over 18K. If that's the standard you may be exempt.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #4 (permalink)
Old 12-27-2006, 04:49 AM
leskwvo leskwvo is offline
leskwvo is starting off with a positive reputation.
This should help
http://www.state.nj.us/mvc/Inspectio...dingDiesel.htm
Erick
2005 F250 PSD
Plant Drive Two tank WVO system.
Hotstk, Vormax, A1000 and Vegtherm
  #5 (permalink)
Old 12-27-2006, 02:45 PM
cookie88's Avatar
2001 Ford F-250
f250juggernaut
They way I read that is if you are tagged at less than 18K you are exempt from testing.
Either way, biodiesel tends to smoke less than #2, so if anything it should help you to pass.....if you end up getting tested.
__________________
Scott
Tags
diesel, emission, emissions, ford, inspection, nj, testing, trucks, tucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
