buyer
Check out this list for a retailer near you. http://www.biodiesel.org/buyingbiodi...tate.asp?st=IL
Thanks for the link Bigredtruckmi. I found a station selling B20 about 1 mile from my office for a nickel a gallon less than straight dino-juice. What's even better is their price for #2 is already 10-15 cents cheaper than what I've been paying at the Shell station by my house. So I can burn B20 for 15-20 cents LESS than what I've been paying for #2....
From what I've read, running B20 I shouldn't need to use any Diesel Kleen or other additives either, right? If that's the case, there's another 5-6 cents a gallon savings - for a total of about a quarter a gallon! That's pretty significant in my book.
You are correct. No additives needed. Just when weather gets below 25 deg I would blend in some #2 to cut the bio to a B5 so it won't jell up or plug filter. Here in Michigan my retailer who delivers to the farm will NOT deliver anything over B5 from Nov to Mar timeframe.
The bio smells different doesn't it?
The really great thing is that the station has the dino and bio pumps right next to each other - so if I want to do 50/50 for B10 or 25/75 for B5 it will easy enough to do. Dunno' what bio smells like - haven't tried it yet.
I'm going to fill up a tank on the way home to give it a try tonight, just to see how the ol' girl likes it. Even if I stick with dino, I think I've found a new and better place to buy my fuel....
One thing on the bio. It will definately clean your fuel system out of contaminates and place it in your fuel filter. So if you notice a power loss after the first tank. Replace the filter as it is getting plugged with very old contaminates.
I started out running Diesel Kleen at the rate of 2/3 ounce per gallon of fuel for about the first 4 - 5 tanks worth, and have been running it at the 1/3 ounce per gallon rate ever since - about 6 - 7 tanks worth now. Having pushed that much Diesel Kleen through the system, do you think it is likely that there are that quantity of deposits left in the tanks?
Actually you are running about a B8.5 with that mix. 12gal B20 X .20 = 2.4 gal of soy
2.4 / 20 = about 8.5%.. If your tank is larger than 20 gal then it will be less % of bio.
You should be good to go with the cleanout BUT I would keep a filter handy just in case for a while. Good luck and enjoy.
Gas prices just jumped here in central Michigan 30 cents but diesel stayed the same.
I calculated it a little differently when I posted since I just did it in my head....
(12g/20g) x 20% = 12 gallons divided by 20 gallons times 20%
I looked at it this way. Since you're dividing by 20 (gallons) on the one hand, and multiplying by 20 (%) on the other, the two "20s" (20 gallons and 20%) cancel each other out - leaving you with your original number (12). BUT you DO have to move the decimal place two positions to the left to account for the fact that 20% is really .20. So you still get a result of .12 (which equals 12%)
Anyway.....
