Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 12-25-2006, 02:28 PM
yamaguy's Avatar
yamaguy yamaguy is offline
Garage is empty, add now
yamaguy is gaining momentum as a positive member of FTE.
buyer
anyone interested in selling biodiesel. I might be interested
__________________
Dale PAA #47
03 F-350 XLT cc LB 4x4 7.3 psd 369,000 MI 9' 2" BOSS Ploy Vee
97 F-250 XLT Extend-cab 4x4 7.3 240,000
  #2 (permalink)
Old 12-25-2006, 09:34 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.
Check out this list for a retailer near you. http://www.biodiesel.org/buyingbiodi...tate.asp?st=IL
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
  #3 (permalink)
Old 01-02-2007, 04:04 PM
CheaperJeeper's Avatar
CheaperJeeper CheaperJeeper is offline
CheaperJeeper is gaining momentum as a positive member of FTE.
Thanks for the link Bigredtruckmi. I found a station selling B20 about 1 mile from my office for a nickel a gallon less than straight dino-juice. What's even better is their price for #2 is already 10-15 cents cheaper than what I've been paying at the Shell station by my house. So I can burn B20 for 15-20 cents LESS than what I've been paying for #2....
From what I've read, running B20 I shouldn't need to use any Diesel Kleen or other additives either, right? If that's the case, there's another 5-6 cents a gallon savings - for a total of about a quarter a gallon! That's pretty significant in my book.
__________________
84 Jeep Cherokee Chief 2-door 4WD - 4.3 Olds V6 diesel, 4.56 gears. Turbo coming soon.
84 Mercedes 300CD Turbo. Bone stock daily driver
86 F250 Super Cab 4x6 (dually), 7.3 Banks TURBO, SMF & ZF5-47, 4.10 gears, 3" Banks straight-pipe exhaust. Mileage unknown
  #4 (permalink)
Old 01-02-2007, 04:59 PM
adambomb's Avatar
adambomb adambomb is offline
2005 Ford F-350
adambomb has a good reputation on FTE.adambomb has a good reputation on FTE.
Yeah your right about not needing DK when using b20. But you might want to use an anti-get for the 80% dino diesel that its mixed with.
__________________
2011 Escape Limited v6 (Loaded) ESP 7yr/65k and Full Ford Maintenance Plan
2005 F350 6.0 (modded) ~450rwhp/900+ft/lb tq
1999 F350 7.3 (normal mods + 13" King Suspension on 40's)
1998 F150 (basic mods + 7" Suspension on 35's/Prerunner fiberglass and skidplace)
1994 Bronco (normal mods + 9" Coil Suspension on 35's)
  #5 (permalink)
Old 01-02-2007, 05:02 PM
You are correct. No additives needed. Just when weather gets below 25 deg I would blend in some #2 to cut the bio to a B5 so it won't jell up or plug filter. Here in Michigan my retailer who delivers to the farm will NOT deliver anything over B5 from Nov to Mar timeframe.
The bio smells different doesn't it?
__________________
B5 soydiesel user
Sirius radio
  #6 (permalink)
Old 01-02-2007, 05:44 PM
Well, here in western WA the temp almost never gets below 25 degrees, so I shouldn't have to worry much about gelling. In the last two months we've had two 3-day stretches and one 4-day stretch where the temps were at or below freezing. The lowest temps we saw were 19 (one day) the first time, 28 the second time and 27 the third time around. And that's unusually cold for this area.
The really great thing is that the station has the dino and bio pumps right next to each other - so if I want to do 50/50 for B10 or 25/75 for B5 it will easy enough to do. Dunno' what bio smells like - haven't tried it yet.
I'm going to fill up a tank on the way home to give it a try tonight, just to see how the ol' girl likes it. Even if I stick with dino, I think I've found a new and better place to buy my fuel....
__________________
  #7 (permalink)
Old 01-02-2007, 06:00 PM
One thing on the bio. It will definately clean your fuel system out of contaminates and place it in your fuel filter. So if you notice a power loss after the first tank. Replace the filter as it is getting plugged with very old contaminates.
__________________
B5 soydiesel user
Sirius radio
  #8 (permalink)
Old 01-02-2007, 10:56 PM
Well, I filled up my rear tank - but it only took 12 gallons. So I guess I'm running about B12 right now (12 gallons B20 + 8 gallons #2).
I started out running Diesel Kleen at the rate of 2/3 ounce per gallon of fuel for about the first 4 - 5 tanks worth, and have been running it at the 1/3 ounce per gallon rate ever since - about 6 - 7 tanks worth now. Having pushed that much Diesel Kleen through the system, do you think it is likely that there are that quantity of deposits left in the tanks?
__________________
  #9 (permalink)
Old 01-03-2007, 11:17 AM
Actually you are running about a B8.5 with that mix. 12gal B20 X .20 = 2.4 gal of soy
2.4 / 20 = about 8.5%.. If your tank is larger than 20 gal then it will be less % of bio.
You should be good to go with the cleanout BUT I would keep a filter handy just in case for a while. Good luck and enjoy.
Gas prices just jumped here in central Michigan 30 cents but diesel stayed the same.
__________________
B5 soydiesel user
Sirius radio
  #10 (permalink)
Old 01-03-2007, 05:27 PM
Not to be ornery here, but you might want to do the second part of that calculation again. By my calculator 2.4 / 20 = .12 or 12%.
I calculated it a little differently when I posted since I just did it in my head....
(12g/20g) x 20% = 12 gallons divided by 20 gallons times 20%
I looked at it this way. Since you're dividing by 20 (gallons) on the one hand, and multiplying by 20 (%) on the other, the two "20s" (20 gallons and 20%) cancel each other out - leaving you with your original number (12). BUT you DO have to move the decimal place two positions to the left to account for the fact that 20% is really .20. So you still get a result of .12 (which equals 12%)
Anyway.....
Yeah, I've kept one handy ever since I started running the Diesel Kleen through it. Good advice....
Haven't noticed any MAJOR jumps lately, but prices for gas have come down a little in the last couple of months (<$2.50 gallon), though the diesel prices haven't changed much. Seems to be more stable in terms of prices....
__________________
  #11 (permalink)
Old 01-03-2007, 06:10 PM
Yes I was doing in my head also at work. Pass the calculator please.
__________________
B5 soydiesel user
Sirius radio
  #12 (permalink)
Old 01-06-2007, 05:48 PM
yamaguy's Avatar
that link is cool, but I'm looking to buy some b-100 on the side is ok. cash I'm in the chicagoland area, but I go to Inidana, st Louis, Iowa, and Wisconsin often. Up to 90 gal a time in the summer
__________________
Dale PAA #47
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
