Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
  #1 (permalink)
Old 12-25-2006, 12:22 PM
Quasimodo Quasimodo is offline
Garage is empty, add now
Quasimodo is starting off with a positive reputation.
Q: Additional Cabling.
Just a quick question: I'm thinking of installing one of those licence plate rearview cameras, but how do I get the video cable into the cabin? Without drilling, that is? I spent sometime looking around yesterday, but couldn't find a useable passage. Also, I'd prefer not to have to run the cable to the engine compartment into the cabin as it may not survive the high temp there.
The truck is a 1998 Mazda B4000 2WD.
Any suggestions?
Thank you very much in advance.
  #2 (permalink)
Old 12-25-2006, 01:02 PM
Nighteyez's Avatar
Nighteyez Nighteyez is offline
Nighteyez has much to be proud ofNighteyez has much to be proud ofNighteyez has much to be proud ofNighteyez has much to be proud ofNighteyez has much to be proud ofNighteyez has much to be proud ofNighteyez has much to be proud ofNighteyez has much to be proud ofNighteyez has much to be proud of
Buy a wireless rear view camera I don't know of any location on the cab you can use for the cabling without drilling a hole, or running up through the engine bay. If you have a flex rear window you can run it through there, but your best bet would be to get a wireless camera.
__________________
Proud to be a Veteran.
93 Bronco EB, 351W/auto, Warn hubs, 235k, 3:55's, 31's
Click Here To Join The Nor-Cal Chapter
  #3 (permalink)
Old 12-25-2006, 01:29 PM
RangerPilot's Avatar
RangerPilot RangerPilot is offline
RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.
The 1998 might be different, but somehow I doubt it. Under both my passenger and driver seat there are rubber grommets for whatever reason. The hole inside I believe is 5/8", plenty big enough for the camera video wire. It'll pop out either under the front seats or right behind. I can get a quick pic if ya like.
  #4 (permalink)
Old 12-25-2006, 02:26 PM
Quote:
Yes, please. I didn't see any grommets from under the cabin yesterday, but I'll look again. Pictures would help a lot.
I thought about the wireless option, but I'd really rather not.
I was looking at the cabling for the radio and other dashboard instruments, any chance there? I'm going to take a look at them more closely to see if there's any entrance point that may be reuseable.
Anybody else's got other suggestions, I'm all ears.
Thanks for your response.
  #5 (permalink)
Old 12-25-2006, 04:54 PM
Here ya go:
http://i112.photobucket.com/albums/n...e-grommets.jpg
That's the passenger side, looking forward, head against the rear tire, just outside of the frame rail.
As you can see, there are two of them. They are in matching locations on the driver's side. This is a regular cab, so if you have an extended cab, they may move slightly. And honestly, I have no idea why these are here.
In the picture, I used the rear one (albeit on the driver's side) and it came out right behind the front seat. The front one should come out underneath the front of the seat I believe.
Hope it helps.
  #6 (permalink)
Old 12-26-2006, 11:59 AM
Thanks! I'll look for these. I didn't see them before, but now that I know what to look for, I may find these holes.
One remaining question is how to power the camera. I'm thinking of simply using the headlight power off of the trailer plug. IOW, I'll have to switch on the headlights to switch on the camera. The other two leads are for L/R signals. I think the more common practice is to splice into the reverse lights leads, but my personal preference really is to have the camera active as long as the key is on. Sort of like the radio, but I don't know which cables back there to splice into to do that.
Anyhow, right now, I'll be happy if I won't have to drill anything.
Thanks again.
  #7 (permalink)
Old 12-26-2006, 03:09 PM
Perhaps you can run a wire into the cab, to a switch to activate the camera? Without knowing the wiring diagram or wires coming out of it I'm not positive that will be applicable, but it should be.
That way you can have it on when you and and off when you want, plus not have to borrow power or splice into any of the rear lights.
  #8 (permalink)
Old 12-27-2006, 01:08 PM
Found them! The grommets, I mean. It's an oblong-shaped hole underneath about where the safety belt for the side-facing jumper seat in the extra cab is. There's one on each side.
That's also an interesting idea about powering the camera. I'll have to read up on the wiring diagram in the shop manual and may be pull out the radio and/or the glove compartment to see what's available. But, that's a small matter. I can always hook it up to the trailer plug.
Excellent. Thank you very much for your help.
  #9 (permalink)
Old 12-27-2006, 03:19 PM
Glad ya got it fixed. Once it's all hooked up let us know how it works.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
