GP fouling?
GP fouling?
I had some hard starts this winter, so I decided to check the GP system and everthing checked ut fine. All teh GP's were testing good, but hte truck would struggle to start. I decided to replace a bang of my gps. When I removed them the element end was coated in a black baked on stuff. What is that, and is there an addative to deal with that? The reason I ask is I did GP's last winter and again this winter, I dont want to make it a yearly event!
Thanks!
Thanks!
Well the only plugs that are recommended here are the ZD-11...im sure others will agree with me. I an autolite or some other brand was used then it was probably why they burnt out. If I were you I would probable change all 8 GPs and put in brand new ZD11 and also change the GP relay. With all that good You should be good as new.
