Pinging/knocking - Premium octane gas - Ford Truck Enthusiasts Forums
Old 12-24-2006, 12:40 PM
Manwith3fords's Avatar
Manwith3fords Manwith3fords is offline
Manwith3fords is starting off with a positive reputation.
I was just wondering if other's here with 5.0's are having to run premium octane gas in there trucks? My 96 F150 4x4 pings/knocks like made when I put regular gas in it.The timing is stock, I have 9mm Ford Racng wires and new autolite plugs. I also have a K/N cone filter on it....I have noticed that it's gotten worse since I put the 31x10.5" tires on it. I have 3.55 gears and when I'm climibing a slight grade it will knock like mad under a "light and lugging" throttle unless I run premium gas. I've checked my spark plug wire routing (mine has the sticker on the rad support) and etc but I don't see anything wrong.
Is there something I might be missing here? Any common problems? It sounds like most of it is coming from 3,4,7 and 8.
Old 12-24-2006, 12:57 PM
Argo's Avatar
Argo Argo is offline
Argo is gaining momentum as a positive member of FTE.
Have you checked the ignition timing? Also, check to see if your knock sensor is working properly, and also check your fuel pressure. You might be slightly too lean under certain driving conditions, causing detonation. Also, do you have a check engine light on? It might be low EGR flow, since the computer uses EGR as a combustion chamber "coolant" to lower combustion temperature and pressure for reduced NOX and increased fuel economy (allows increased ignition advance). If there is no EGR flow (or not enough) the computer will allow too much advance and ping. Also since the ECM cus back on fuel flow with EGR, if there is not enough EGR, it will be too lean, and therefore it will ping.
Old 12-24-2006, 01:21 PM
Good info because I've been having the code for "Insufficient EGR flow" come on and off for the last little while. I bought a EGR gasket so I can remove/clean the valve so I guess I better get out my book and start doing some checks/tests as well. I'd really like to fix this problem as it drives me nuts listening to it.
I'll have to go out to the garage and get my Haynes book but what could be reducing the EGR flow? Is there a sensor for that? I didn't think my 96 had a knock sensor? That code has been registered 4 or 5 times in the last few months. My buddy has a Snap-On solus ro read the codes so that's how I know what the code was.
Old 12-24-2006, 01:59 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
The 96 uses a differential pressure feedback (DPFE) sensor to sense EGR flow directly. I'm sure the Haynes manual lists some test procedures for that sensor. I'd also try cleaning the mass air flow meter sensing elements. Just gently wipe off the hot wires with rubbing alcohol and a q-tip. Be careful not to break either of the wires.
Old 12-24-2006, 02:07 PM
vman vman is offline
vman is starting off with a positive reputation.
Dis it come with 31 inch tires or 235/15?Might have to reset the psom.I might be out in left field on this one.Mine came with smaller tires and I put 31's on.Reset the psom for the 31's and I think it shifted better with the original setting.Seems to lug more but mine doesn't ping.
Old 12-24-2006, 02:40 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Be sure to check the EGR tube for rust or a crack as well.
Old 12-24-2006, 03:07 PM
No cracks in the tube, I'll see what it looks like as soon as I get it off. I never reset my psom when I put the new tires on - 235/75/15 was the stock size. The truck drives fine and the pinging is almost totally gone with premium gas but I still want to cure it if possible. I'll clean the mass air as well - good tip....I'm a diesel truck tech so I don't work on EFI gas stuff very often. All my summer toy's are carb'd too. Mine lugs a little bit but nothing too severe. I have one long grade to climb on the way home each day in traffic and that is where I alway's hear the rattling. I'm off all this week so I'll have a look at it.
Old 12-29-2006, 10:04 AM
95X15 95X15 is offline
95X15 is starting off with a positive reputation.
Remember that the 31" tire swap is like going to a 3.3 rear end vice 3.55 original. Does it down shift on the grade? The 4R70W is a wide ratio transmission to allow a higher rear end (Lower number) to run on the highway but has lower gear to allow pulling from first gear.
In addition to EGR check canister purge operation and any vacuum leaks.
Good luck.
Old 12-29-2006, 10:37 AM
Ben-jamin Ben-jamin is offline
Ben-jamin is starting off with a positive reputation.
you may need to remove the upper intake to throttle housing "neck" (hope i said that right). It seems they carbon up in those egr passages and will give you that code and problem; all you'll need to replace is one gasket $4-5. i've seen folks replace the DPFE and egr and still have to do this.
to see if you need to do this, remove the egr and the intake hose from mass air sensor to throttle body. Hold the throttle open while blowing compressed air into the intake side of the egr passage. You should really hear it flowing into the throttle bore; if you don't then you know it's clogged.
Old 12-29-2006, 11:40 AM
Good tips, I'm hoping to look at this in the next couple of days....I'll keep you posted.
Old 01-06-2007, 04:14 PM
I vacuum checked my EGR valve today - works good, I did find the EGR passage in my plenum was plugged up - I cleaned it out and I didn't hear any rattling on the hills when I came home from work so maybe that's all that was wrong. I'll try cleaning the mass air sensor tommorow. Where is the knock sensor? My Haynes book talks about it but it doesn't tell you where it's located? I'll also check the EGR canister purge operation and differential pressure feedback (DPFE) sensor tommorow. I didn't hear or see any signs of a crack in the EGR tube - but I'll look closer tommorow.
Old 01-06-2007, 09:02 PM
EPNCSU2006's Avatar
The 96 may or may not have a knock sensor, but if it does, it is here, looking at the back side of the engine:
Old 01-06-2007, 09:42 PM
Cool, thanks for the tip. I'll have a look at it tommorow.
Engine Pings unless I use Premium t4kne 1987 - 1996 F150 & Larger F-Series Trucks 15 04-05-2007 10:15 PM
94 Explorer knock sensor location Bodien460 Explorer, Sport Trac, Mountaineer & Aviator 1 01-29-2006 03:24 AM
Interesting "Anti Knock" (ping) Article jbabbler 3.0L V6 3 01-07-2005 11:02 PM
2.3 Pinging RangerXLT89 4 Cylinder Engines 5 12-27-2004 10:22 AM
Ping/knock 351M jopey 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 19 08-26-2001 02:22 AM
Tags
1992, 302, dpfe, f150, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
