truck will not crank. drain fuel replaced filter. truck turns over but acting like it is not getting fuel. problem started after truck set up for a couple of weeks. new to diesels and scrathing my head.
I think i found the hpop resevoir. is it in front of the fuel filter but lower. I do not see a place to check the level.
It is the aluminum rectangular box on top of the front of the engine. There is a plug in the top of it, either hex head or square drive plug. Pull that plug and look inside with a flashlight to determine if it is full of oil, within a 1/2 inch of top. If not fill it up with a small funnel with regular diesel motor oil.
Also check to make sure that the fuel filter housing is full of fuel. It sounds like you may have a problem with your fuel heater element in your filter housing. Try unplugging it and make sure your #22 fuse is not blown and she may start right up.
You have a problem with a check valve in the HPOP allowing the oil to drain out. there is a fix to it, but I do not know what it is. I will look but I know there are some guys in this forum that can tell you off the top of their head
When you say oil do you mean diesel fuel? This is the first time it has hapened and it was when i had not cranked it for a couple of weeks. I will check on the valve to see what help someone can give me. I am real happy that it cranks for now.
