1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Wiper Blades - 24" versus 20" - Go For The 24"!!!
Old 12-24-2006, 09:07 AM
Beachbumcook's Avatar
Beachbumcook
Beachbumcook is offline
Got Diesel?
Originally Posted by Bear Hunter
Hows the 24" fitting on your the passenger side? I found it was a hair too long at that location. The end of the tip did not contact well with the glass due to the curvature of the windshield on the side. If I was to do it again I would get the 24" for the drivers side and the 22 for the passenger.
So far mine loks OK... I have sprayed enough washer fluid to test and it cleans 100% of the area. From the interior it "looks" like what your commenting about... but from the outside... it cleans it just fine. Even if a small section at the very bottom is missed, it still cleans the rest of the windshield... but again... I'm not having that problem.
By the way... since I drive an Excursion, I needed a rear-window wiper blade as well and upgraded from a 16" to a 17" wiper blade. Not much of a visible improvement... but it makes me feel good about upgrading it anyway!!!
Old 12-24-2006, 01:26 PM
kw5413's Avatar
kw5413
kw5413 is offline
Originally Posted by Beachbumcook
Was needing new wiper blades for my Excursion (also works for SD's as well) and was previously using the stock 20" wiper blades... but decided to try 24" ones instead.....
There goes your warranty....right out the window.
The additional surface area drag will 'cause undue stresses on the wiper motors thereby causing them to fail. This is turn will likely cause a short your electrical system causing a FICM failure. This in turn will surely cause your exhaust bearings to fail and your turbo to...well...you get the picture.
Modifications kill warranties. Better be sure to put the stock blades back on before you take it into the dealer.
Old 12-24-2006, 03:15 PM
JORYLEE76's Avatar
JORYLEE76
JORYLEE76 is offline
hey does that mean i need to put the stock lugnuts back on before i go in for an oil change... i mean i could seem like the "aftermarket" one's made the truck work the oil harder there fore meaning i had to get the oil changed earlier then recomended
Old 12-24-2006, 07:46 PM
Customz's Avatar
Customz
Customz is offline
Nicely done.
I bet some whacked out EE could prove that...
I am in need of new wipers and may consider the 24s...Good work Jeff.
Old 12-25-2006, 06:20 PM
HDMalibuMan1's Avatar
HDMalibuMan1
HDMalibuMan1 is offline
Bought a pair of 24's for the 250 yesterday. Drove through the rain today and they worked GREAT. Thanks for the suggestion.
Old 12-25-2006, 10:37 PM
Beachbumcook
Got Diesel?
Another satisfied customer....
Wow... you had rain and I had to squirt a whole gallon of washer fluid just to watch and see if the larger blades worked!!! Dam... $1.39 down the drain... but I do have the cleanest windshield in town!!!!
By the way.... I am well past the 3/36 warrenty... so I was not worried about voiding it - thanks Keith (KW) for getting this thread of topic... you funny guy.
Old 12-26-2006, 08:44 AM
kw5413's Avatar
kw5413
kw5413 is offline
Your very welcome. It's in my contract....
Old 12-26-2006, 08:40 PM
Kep4's Avatar
Kep4
Kep4 is offline
Jäger
Great info Jeff, thanks for posting. It 'never' rains in So Cal but my PSD is coming up on 2 years old so I guess they're due for replacement.
I'll keep the stock wipers in case of warranty work....
Old 12-27-2006, 06:39 AM
spikebee's Avatar
spikebee
spikebee is offline
LOL...I don't think anybody would even notice 24" blades. But don't get cocky, if you go in with dual 24's with 36 green L.E.D.'s on each blade and 3" wings to hold 'em tight aginst the windshield in a tornado, your tech might just have a hissyfit and deny your claim!
Old 12-27-2006, 07:18 PM
ryaneverk2's Avatar
ryaneverk2
ryaneverk2 is offline
I've been using 24" blades for a year now. Love them. Haven't had any issues with them being too big or anything like that. They clear the whole windshield and leave the tiniest of shark fins on the bottom in between them.
In fact, just bought a new pair a couple weeks ago to replace the current ones... which are still doing fine, so I guess I've got an extra pair for a while.
Whatever brand anyone gets, go for the 24" blades.
Old 12-28-2006, 06:48 PM
mrxlh's Avatar
mrxlh
mrxlh is offline
Jeff, I must say, excellent cheap mod. I put a set on today, wow what a difference.
Old 12-28-2006, 07:17 PM
wcurtis's Avatar
wcurtis
wcurtis is offline
Got the 24" one two days ago, works great! Thanks for the tip!!!
  #28
Old 12-28-2006, 07:39 PM
redford's Avatar
redford
redford is offline
Received 1,562 Likes on 910 Posts
But how do you avoid the dreaded windshield wobble?
  #29
Old 12-28-2006, 08:06 PM
mrxlh's Avatar
mrxlh
mrxlh is offline
Drive faster
  #30
Old 12-28-2006, 08:10 PM
redford's Avatar
redford
redford is offline
Angry
Originally Posted by mrxlh
Drive faster
I was going for more beer, but that answer works also!
Quick Reply: Wiper Blades - 24" versus 20" - Go For The 24"!!!
